Topic: Led cube 5*5*5 & voice sensor (Read 2635 times) previous topic - next topic
Ramos
hello guys, I have to do a final project in my last year at school
(god I cant belive i'm going to finish with that)
and I though to do a Led Cube as i'm sure many of you know what i'm talking about,
the only change is the I want to put a voice sensor in the circuit that after every sound it shall hear
the led will run (as the sensor in the pocket plasma)
Led Cube:
http://www.youtube.com/watch?v=CfGrb50qSDI
Pocket Plasma:
http://www.youtube.com/watch?v=7JBR_tkRmAw
My friend told me that I could use mega arrduino for make the project easier,
but actually I never used  an arduino before, if someone could help me with the
circuit it could very help me, (circuit of the led cube with the arduino, if you could to put the sensor
so it shall be even greater but you not have to  :P )
My skype is : tomer_zamir
CrossRoads
Have you seen this link?
http://www.jameco.com/Jameco/workshop/JamecoBuilds/4x4x4ledcube.html
Its one of the best I've seen on cubes.
5x5x5 is just a little bigger.
Adding a sound sensor is easy - see the knock sensor examples in playground as an example.
Ramos
at the knowledge required wrote that I need to know AVR microcontroller programming skills,
and I never learn about the AVR programin and my teacher said that I must use C# / C++ / assembly at coding
CrossRoads
Well, I can't you programming lessons via the forum.
Suggest you start with the Learning section, or get a programming book.
Ramos
It's not working without the AVR programing? I cant use a C# code?
CrossRoads
I'm sure you can. I'm not knowledgable about C# programming and downloadig to an AVR outside of the Arduino IDE.
Ramos
allright, thanks for every thing, if I'll more questions I'll write here,
thank you a lot :)
