Topic: GPS Bee and Bees Shield from Seeedstudio (Read 2644 times) previous topic - next topic
trodi
I'm new to the hardware side of things so pardon any faux pas. I'm trying to read GPS NMEA strings on a software serial and write them out to the hardware serial so I can see them on the serial monitor, but I can't seem to get any NMEA strings.
I have an Arduino Uno R3, Bees shield, and GPS Bee.
Here's the code I've uploaded to my board (I've tried baud rate of both 9600 and 4800 for the software serial).
Code: [Select]
#include "SoftwareSerial.h"
const unsigned int GPS_RX = 11;
const unsigned int GPS_TX = 12;
SoftwareSerial ss(GPS_RX, GPS_TX);
  Serial.begin(9600); //baud rate for pc hw serial
  pinMode(GPS_RX,INPUT);
  pinMode(GPS_TX,OUTPUT);
  ss.begin(9600); //baud rate may be wrong? 4800
  delay(2000);
  Serial.print("\nloop | ");
  while(ss.available()) {
    Serial.write("ss is available |");
    int data = ss.read();
    Serial.write(data);
    Serial.write("|");
  delay(2000);
This is what I normally get back:
Code: [Select]
loop |
loop |
loop |
loop |
Sometimes I see that the software serial is available and Serial.write() returns a space while Serial.print() return a zero (though it seems to only happen if I'm holding everything together in my hands a certain way). I'm inside an apartment, so maybe it's not connecting, but shouldn't I regularly receive something from the GPS?
Code: [Select]
loop | ss is available | |
Similar issue with no resolution:
http://www.seeedstudio.com/forum/viewtopic.php?f=18&t=2701&p=14996&hilit=+gps+bee#p14996
Any suggestion as to what I'm doing wrong would be much appreciated. If I can provide any more information, please tell me. Thank you.
PaulS
The XBee shield has a bunch of jumpers on it. Where are yours?
trodi
Quote
My Bees shield came with 2 jumpers. When running this code, Bee1_TX jumper is on pin 12 and Bee1_RX is on pin 11. I originally tried pins 9 and 10 if that's relevant. Is there a wrong way to put jumpers on? This only requires the jumpers, not any wires, correct? Thanks.
trodi
Also, I have the switch pointed at Atmega.
I tried swapping out the GPS bee as well as the Bees shield (since I have 2 of each) to try to rule out receiving a malfunctioning piece of hardware. I get the same results.
trodi
For cross reference, I've posted the same post on Seeed Studio's forum here:
Again, any help/suggestions with this would be greatly appreciated. I've tried everything I can think of many times over with no luck. Thanks.
