Topic: RN-XV setup with arduino uno shield (Read 3205 times) previous topic - next topic
gilboash
hey
I own an arduino uno, and for my new project I need it to be wireless, so i've decided to use the RN-XV with SMA connector (http://www.sparkfun.com/products/11047) with the xbee shield (http://www.sparkfun.com/products/9976).
Now I'm wondering, do I need an XBEE explorer USB (http://www.sparkfun.com/products/8687) in order to first-configure-it? Or it is possible that all configurations will be done through the arduino uno? and if so- how? is there a special arduino code for this mode? which pins to connect?
TX !
Waltermixxx
you can use the arduino to communicate with it.
set the switch on your shield, so the usb port on arduino talks directly with the rn-xv...
then go into the serial monitor and communicate directly with it...
then you can configure directly :)
check out my threads on the subject :) along with some code for turning led's on and off :)
TinkerFailure
You can use the Arduino to configure the WiFly. I tried configuring it via wifi, using the Arduino only as a power source, and it worked well.
I wrote a short guide here:
http://www.tinkerfailure.com/2012/02/setting-up-the-wifly-rn-xv/
Let me know how you get on.
C
gilboash
Hey fellas
it took me a while, but now I'm back on the project  :*
anyway I'm trying to use u'r advices, but having some difficulties to get to the rn-xv configuration.
I'm trying to configure the rn-xv via the arduino, using the xbee shield. I used your code trying to configure the wifly pins 2,3 or 11,12, but no response at all from the device.
I also tried setting the UART/D-LINE switch both ways but no response.
can u please help?
TX!
