Hi All,
I have a have a powermonitor that suddenly stopped working after I added a feature. I have not been able to figure out what happened but what ever I do I keep getting a socket error, anyone that can help?
The output I get from CloudMQTT is the following:
2019-08-18 14:51:49: New client connected from 77.213.84.230 as Hest1 (c1, k15, u'uecaymxu').
2019-08-18 14:51:49: No will message specified.
2019-08-18 14:51:49: Sending CONNACK to Hest1 (0, 0)
2019-08-18 14:51:49: Received SUBSCRIBE from Hest1
2019-08-18 14:51:49: Entrance/sensor1 (QoS 0)
2019-08-18 14:51:49: Sending SUBACK to Hest1
2019-08-18 14:51:49: Socket error on client Hest1, disconnecting.
The code is too long so I have attached it instead and below is a snipped from the publishing part
publishData(watt, kwh, ledflag);
void publishData(float p_watt, float p_kwh, float p_ledflag) {
StaticJsonBuffer<200> jsonBuffer;
JsonObject& root = jsonBuffer.createObject();
// INFO: the data must be converted into a string; a problem occurs when using floats...
root["watt"] = (String)p_watt;
root["kwh"] = (String)p_kwh;
root["Charger_ready"] = (String)p_ledflag;
root.prettyPrintTo(Serial);
char data[200];
root.printTo(data, root.measureLength() + 1);
client.publish(MQTT_SENSOR_TOPIC, data, true);
yield();
// function called when a MQTT message arrived
void callback(char* p_topic, byte* p_payload, unsigned int p_length) {
Serial.print("Message arrived [");
Serial.print(p_topic);
Serial.print("] ");
char message[p_length + 1];
for (int i = 0; i < p_length; i++) {
message[i] = (char)p_payload[i];
message[p_length] = '\0';
Serial.println(message);
if (!processJson(message)) {
return;
void reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
Serial.println("INFO: Attempting MQTT connection...");
// Attempt to connect
if (client.connect(MQTT_CLIENT_ID, MQTT_USER, MQTT_PASSWORD)) {
Serial.println("INFO: connected");
client.subscribe(MQTT_SENSOR_TOPIC);
Serial.print("ERROR: failed, rc=");
Serial.print(client.state());
Serial.println("DEBUG: try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
/********************************** START PROCESS JSON*****************************************/
bool processJson(char* message) {
StaticJsonBuffer<BUFFER_SIZE> jsonBuffer;
JsonObject& root = jsonBuffer.parseObject(message);
if (!root.success()) {
Serial.println("parseObject() failed");
return false;
if (root.containsKey("kwh")) {
kwh_from_HA = root["kwh"];
LEDstate_from_HA = root["Charger_ready"];
callback_after_restart = 1;
return true;
current-mqtt-for-forum.ino (9.6 KB)
