Hi, I am developing a small project (a people counter )with an arduino due. In the i2C port (SDA and SCL) I have connected a Panasonic Grid EYE. In the SPI port it is conected a TFT LCD from Adafruit that shows the Thermal image that the sensor provides. When I put all the code together , both things worked. When I started using the serial monitor (at 115200 baud )the LCD stoped working. First I thought that de LCD was broken and and I took it out of the project. Later I noticed that sometimes when I restart the board it takes a while to start and it works really slow until I change the USB port in my PC. I was for a certain time with this problem until I decided to try with another PC , and the same happened the program takes like 7 times more than usual :o . How can I fix this?????????
I decided to go back to the LCD option and it works , but now i need to use both things at the same time to check if the program is working fine.
I tried conecting the Due with another arduino (uno - nano) , so the Due reads the sensor and shows the thermal image in the LCD , then the number of people detected are sent to the Nano that print them on the serial monitor. But I didnt succeed in establishing the connection betwen arduinos.
Does anyone know how to solve the compatibility problem between the LCD and the serial monitor ? or how to establish the connection between the arduino due and the nano ?
This is the LCD:
