Here is the first cut of the library if you want to use it. These file need to be in a new directory called ServoTimer2 in the same subdirectory as the other Arduino libraries.
Header:
ServoTimer2.h - Interrupt driven Servo library for Arduino using Timer2- Version 0.1
Copyright (c) 2008 Michael Margolis. All right reserved.
This library is free software; you can redistribute it and/or
modify it under the terms of the GNU Lesser General Public
License as published by the Free Software Foundation; either
version 2.1 of the License, or (at your option) any later version.
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
Lesser General Public License for more details.
You should have received a copy of the GNU Lesser General Public
License along with this library; if not, write to the Free Software
Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA
This library uses Timer2 to drive up to 8 servos using interrupts so no refresh activity is required from within the sketch.
The usage and method naming is similar to the Arduino software servo library http://www.arduino.cc/playground/ComponentLib/Servo
except that pulse width is in microseconds for greater accuracy rather than degrees.
(A future version may also support degrees if this was required)
A servo is activated by creating an instance of the Servo class passing the desired pin to the attach() method.
The servo is pulsed in the background to the value most recently written using the write() method
Note that analogWrite of PWM on pins 3 and 11 is disabled when the first servo is attached
The methods are:
ServoTimer2 - Class for manipulating servo motors connected to Arduino pins.
attach() - Attaches a servo motor to an i/o pin.
write() - Sets the servo pulse width in microseconds.
read() - Gets the last written servo pulse width in microseconds.
attached() - Returns true if there is a servo attached.
detach() - Stops an attached servos from pulsing its i/o pin.
The library takes about 824 bytes of program memory and 32+(1*servos) bytes of SRAM.
The pulse width timing is accurate to within 1%
// ensure this library description is only included once
#ifndef ServoTimer2_h
#define ServoTimer2_h
#include <inttypes.h>
#include <wiring.h>
#define MIN_PULSE_WIDTH 750 // the shortest pulse sent to a servo
#define MAX_PULSE_WIDTH 2250 // the longest pulse sent to a servo
#define DEFAULT_PULSE_WIDTH 1500 // default pulse width when servo is attached
#define FRAME_SYNC_PERIOD 20000 // total frame duration in microseconds
#define NBR_CHANNELS 8 // the maximum number of channels, don't change this
typedef struct {
uint8_t nbr :5 ; // a pin number from 0 to 31
uint8_t isActive :1 ; // false if this channel not enabled, pin only pulsed if true
} ServoPin_t ;
typedef struct {
ServoPin_t Pin;
byte counter;
byte remainder;
} servo_t;
class ServoTimer2
public:
// constructor:
ServoTimer2();
uint8_t attach(int); // attach the given pin to the next free channel, sets pinMode, returns channel number or 0 if failure
// the attached servo is pulsed with the current pulse width value, (see the write method)
void detach();
void write(int); // store the pulse width in microseconds (between MIN_PULSE_WIDTH and MAX_PULSE_WIDTH)for this channel
int read(); // returns current pulse width in microseconds for this servo
boolean attached(); // return true if this servo is attached
private:
uint8_t chanIndex; // index into the channel data for this servo
// the following ServoArrayT2 class is not implimented in the first version of this library
class ServoArrayT2
public:
// constructor:
ServoArrayT2();
// channels are assigned consecutively starting from 1
void detach(int); // detach the servo on the given channel
void write(int,int); // store the pulse width in microseconds (between MIN_PULSE_WIDTH and MAX_PULSE_WIDTH)for the given channel
int read(int); // returns current pulse width in microseconds for the given channel
boolean attached(int); // return true if the servo on the given channel is attached
private:
#endif
Source code in next post:
