05/Mood cue - servo tries to turn more
I'm a complete newbie at electronics, but I got myself a starter kit yesterday and so far I'm loving it. I've gone through the mood cue project and I have noticed that if I map the angle as is suggested:
angle = map(potVal, 0, 1023, 0, 179);
then when I turn the potentiometer all the way to max and the angle reaches 179, the servo is still trying to turn. Of course it cannot turn, it's all the way to the end, but I can hear the motor struggling, it's even moving the servo on my desk due to the vibration and it won't stop unless I turn it back down a bit. Same thing if I map the max to anything >=175.
If I map the angle to 0-170 degrees though, it doesn't do that. It just stops working as I expected it to do anyway.
Since I have never used a servo before in my life, my questions are: why is it doing that? Is that normal for a servo? Or for the servo bundled in the kit for that matter? Or am I probably doing something wrong?
I even changed the layout a bit, removed the potentiometer and added two buttons, one to increase the angle, the other to decrease it and an LED to show if I've reached the limits. And it still does that if I use anything from 175 to 179 as the max limit, so I think I've ruled out the potentiometer as the cause. Here's the code I'm using for this layout, though I don't think it really matters:
#include <Servo.h>
Servo myServo;
const int ledPin = 8;
const int servoPin = 11;
const int sw1 = 4;
const int sw2 = 7;
int sw1State = LOW;
int sw2State = LOW;
int servoDeg = 0;
  myServo.attach(servoPin);
  pinMode(ledPin, OUTPUT);
  myServo.write(servoDeg);
  pinMode(sw1, INPUT);
  pinMode(sw2, INPUT);
  sw1State = digitalRead(sw1);
  sw2State = digitalRead(sw2);
  if (sw1State == HIGH && sw2State == HIGH) {
  else if (sw1State == HIGH) {
    if (servoDeg < 170) {
      digitalWrite(ledPin, LOW);
      servoDeg = servoDeg + 1;
    else {
      digitalWrite(ledPin, HIGH);
  else if (sw2State == HIGH) {
    if (servoDeg > 0) {
      servoDeg = servoDeg - 1;
    else {
  Serial.println(servoDeg);
  delay(10);
I face the same problem on my starter kit. Until servo angle < 169 everything is fine. I also noticed that the poti is "shaking" at max level between 1015 up to 1023 Ohm. Here is an example for this:
otVal: 1023, angle: 179
potVal: 1015, angle: 177
potVal: 1023, angle: 179
potVal: 1016, angle: 177
Could this be the reason for this?
Yesterday I tried this example with my starter kit and I noticed the same issue. Over 170 the servo starts shaking ...
Dude, I had the same problem too. And I found the solution. The problem is not in your code or servo. The problem is in your potentiometer. It's not fixed correctly. Try pressing the pot meter down into the breadboard when you turn the knob or look for a more permanent solution to the press the pot meter into the breadboard.
Hope it helps......
I had the same issue and thought it to be the potentiometer but after testing the resistance on a multimeter the pot seemed fine.
I ran a few numbers and the capacitor connected to the servo appeared to be redundant.
Remove the capacitor from the servo connection and it will work fine
I had the same issue as described by the original poster.
Changing the map values did not help; nor did removing the capacitor at the servo.
I'm new to this, so I do not know how to further troubleshoot yet. Just wanted to let you know you're not alone!
For reference, I unplugged all components except for the potentiometer and then read the analog input value when the pot was turned all the way up. It remained at 1023 this time, suggesting that the issue was somehow related to the servo.
I just completed this project and I had the same problem. I installed a protractor to it and noticed that when I put a max output of 170 it was roughly 180 degrees. It seems like the potPin values range from 0-170. Anything over and it tries to go beyond 180 degrees and its physically limited causing it to shake.
