I just installed the support package for Arduino in my Simulink environment so I am able to program it the model-based way instead of purely with C-code. I read here that for now all DUE functionality is supported except for DAC and CAN-Bus channels. Also I read that there is "Interactive Tuning and monitoring" support. I have tested the setup by programming digital output 13 as a flashing LED using the "Digital Output" block from the Simulink library. This works fine.
Now I have some questions towards using the Simulink-DUE environment:
Who else on the forum has used this setup? It would be nice to have a chat on the possibilities
"Interactive Tuning and monitoring" --> How do you do that? --> I found this! Very cool, you can read here how to do that.
Anybody an idea when DAC and CAN will be supported? CAN-bus is 1 of the biggest advantages for me in using the DUE because I am planning some automotive small projects where CAN is basic.
In the Simulink DUE Options I saw you can configure the WiFi- and Ethernet- Shields for the DUE. I had no idea these shields are available for the DUE. Anybody an idea where I can buy these?
The problem isn't that the Due hasn't got a CAN transceiver on board, because it has 2 of them built into the micro (although you do need to add a PHY), what's holding it back is that this has a completely different implementation than a standard Arduino which needs an external CAN transceiever, the standard shield isn't quite compatible with the Due either.
