vaj4088:
As usual, it would be useful to provide the ENTIRE code instead of just a snippet.
I would gladly do that but it is 1035 lines of code; and I think the issue is with a very specific part, in the parsing section: so with all due respect I hope to spare you the nightmare of wading through what might be avoided maybe by starting with the part that starts the crash and MCU restart?
You may have avoided one nightmare but created another by forcing unpaid helpers to play guessing games and ask questions about unseen portions of the code.
vaj4088:
Do you REALLY want your help delayed?
Here you go, I hope this helps; thanks in advance.
strtokIndx = strtok(NULL, ","); // this continues where the previous call left off
strcpy(messageFromPC, strtokIndx); // this is a text string: copy it to messageFromPC:
// sensor identification, sensor "A" or sensor "B", or C or D
Serial.println(F(" 6 "));
Serial.println();
When parsing the last piece, strtok is looking for a ',' which does not exist. In testing, it has not appeared to make a difference between using strtok(NULL, NULL) or strtok(NULL, ","), but perhaps there is something in your case which does make a difference.
There are two thing to test.
First, see if strtok(NULL,NULL) improves things.
Second, try formulating the transmitted string like this with a period after the letter
<99.99,22.25,3.47,11,22,A.>
Serial.println();
Then parse with
strtok(NULL, ".")
Great, thanks a lot for that, I had not noticed this.
Just a question here: would/could there be a reason why most of the received messages do get parsed succesfully?
Then, your suggestion is to include a . after the A however should that not be a , ?
For sure I will be testing both suggestions and let you know asap.
EDIT: sorry, I misread your suggestion "..parse with strtok(NULL, "."); evidently this requires A.
My guess would be that in the rare, failing case, there is no null terminator.
If there is no null terminator on receivedChars[] or tempChars[] I believe that the behavior of strtok will be undefined when parsing the last piece. The esp8266 also has a pretty short watchdog timer which causes resets if things get blocked
cattledog:
Why there would be a missing '\0' is a mystery.
The strtokIndx = strtok(NULL, NULL); resulted in continual crashes, no parsing possible. Next will be the A. test as well as a bare-bones program version (Robin2).
Actually this might be a clue if you have done this correctly. Did you only replace the last use of strtok for the message and the printing of the 6. The earlier cases should have been left unchanged. If that is the situation for this test, then there must be something wrong with the null termination.
strtokIndx = strtok(NULL, NULL);// this continues where the previous call left off
//strtokIndx = strtok(NULL, ","); // this continues where the previous call left off
Serial.println();
Actually, I have higher hopes for the addition of another token after the A. It could be a ',' or a '.' --just another character that strtok is looking for instead of the end of the string when looking for a non existent ','.
cattledog:
Serial.println();
Indeed, only the last use of strtok had been changed.
Next today the A. test and corresponding strtok change will be done.
Would it not be much more elegant to simply add a ',' as a terminating character here
if (recvInProgress == true) {
if (rc != endMarker) {
receivedChars[ndx] = rc;
ndx++;
if (ndx >= numChars-1) {
ndx = numChars - 2; // and forcefully leave 1 extra character of space here
else {
receivedChars[ndx] = ','; // put an extra separator
receivedChars[ndx+1] = '\0'; // terminate the string
recvInProgress = false;
ndx = 0;
newData = true;
Deva_Rishi:
ndx++;
else {
ndx = 0;
newData = true;
The issue with that I think is that , are used as separator, and termination is done with endmarker: this allows the program to differentiate between "continuous" data and "last" data.
What advantage would the use of , as endmarker have?
what was suggested earlier just so strtok() is looking for something that it can find.
cattledog:
my point also, when a '>' endmarker is received do not just terminate with a NULL but add a ',' separator as well. I can't see anything being wrong with the terminating NULL other then strtok() not finding it !
Deva_Rishi:
Indeed, just to recap: now A is being sent without anything behind it, so placing a . or a , after the A and have strtok identify this character: strtokIndx = strtok(NULL, "."); in case of A.
Right?
Right?
I think the suggestion was to add the final token character in the receiving code instead of in the transmission. In Robin's code, the end marker is replace by '\0' and it was suggested that a separator be added before the Null. You could probably send the final separator in the transmission and add another at the receive.
I think the bigger issue is why strtok with the ESP8266 appears to not find the null terminator when parsing something at the end of the character string.
cattledog:
Thanks for that clarification cattledog. Tomorrow afternoon tests will be done, parameters and results I post asap.
cattledog:
Serial.println();
So far so good, I have been simulating several hours of transmissions/receptions, no crashes so far (in the previous setup there would have been several crashes). I keep this running another 24 hours (RX every 5 seconds) and let you know the result.
cattledog:
After 24h testing (RX every 5 seconds instead of every 20 minutes: simulating 10 days in each hour of the past 24h), 2 crashes occured. An order of magnitude better than before the change according to cattledog suggestion.
But what can be done to eliminate these spurious crashes completely? The test is now run in ideal lab conditions, and I suspect the same issue being present because the crash still occurs when parsing the last part: the transmitter ID (A.. to D).
Is there a fallback for this last parsing instruction, ie building in a condition to somehow verify invalid ID characters?
Or would the consensus be that this result is "good enough"?
