Hi!
Using this tutorial and the code below, I've been able to connect my NodeMCU with a hotspot of my phone (and have been able to control the LED).
However, when I try to connect to my router, it keeps printing '............'. Any idea what I'm doing wrong? And how to solve?
Edit, the answer: I turned out to have a dual band router transmitting both 5GHz and 2.4GHz. The NodeMCU can only connect to 2.4GHz. The solution for me was logging into my router and changing the SSID (name) of the 5GHz version to ORIGINALNAME-5GHz. All my devices now connect to the 2.4GHz option. And NodeMCU works.
#include <ESP8266WiFi.h>
const char* ssid = "***";
const char* password = "***";
int ledPin = 13; // GPIO13
WiFiServer server(80);
delay(10);
pinMode(ledPin, OUTPUT);
digitalWrite(ledPin, LOW);
// Connect to WiFi network
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
// Start the server
server.begin();
Serial.println("Server started");
// Print the IP address
Serial.print("Use this URL to connect: ");
Serial.print("http://");
Serial.print(WiFi.localIP());
Serial.println("/");
// Check if a client has connected
WiFiClient client = server.available();
if (!client) {
return;
// Wait until the client sends some data
Serial.println("new client");
while(!client.available()){
delay(1);
// Read the first line of the request
String request = client.readStringUntil('\r');
Serial.println(request);
client.flush();
// Match the request
int value = LOW;
if (request.indexOf("/LED=ON") != -1) {
digitalWrite(ledPin, HIGH);
value = HIGH;
if (request.indexOf("/LED=OFF") != -1) {
value = LOW;
// Set ledPin according to the request
//digitalWrite(ledPin, value);
// Return the response
client.println("Content-Type: text/html");
client.println(""); // do not forget this one
client.println("<!DOCTYPE HTML>");
client.println("<html>");
client.print("Led pin is now: ");
if(value == HIGH) {
client.print("On");
client.print("Off");
client.println("
client.println("<a href=\"/LED=ON\"\"><button>Turn On </button></a>");
client.println("<a href=\"/LED=OFF\"\"><button>Turn Off </button></a>
client.println("</html>");
delay(1);
Serial.println("Client disonnected");
Serial.println("");
Thanks in advance!
