@Magician Thanks for your suggestions, the reduction in resolution to 16 bit vs 24 is not a problem.
Is it feasible to run two of these AD7705 16 bit modules from an Uno? Also, if I were to use the 7705 ADC board, can I still use my shield wire from my load cell? and how?
I ran into a problem when trying to read from two hx711's in the same program, not sure if it was a library problem or what? Will I have the same problem with AD7705 ADC?
Here is my code for those that have asked. It is currently set to run with only one load cell. I have code in there to set sampling frequency but was rendered useless when using the hx711 amp boards because they output data too slowly. I need a minimum of 100hz per load cell.
#include "HX711.h"
#include <SPI.h>
#include <SD.h>
#include <Wire.h>
#include "RTClib.h"
float calibration_factor = -7050; // Get cal number from cal sketch //
#define DOUTL A0
#define CLKL 8
//#define DOUTR A1
//#define CLKR 11
HX711 leftloadcell(DOUTL, CLKL);
// Call HX711 scale(DO, CK)} //// LEFT POLE ////
//HX711 rightloadcell(DOUTR, CLKR);
// Call HX711 scale(DO, CK)} //// RIGHT POLE ////
// how many milliseconds between grabbing data and logging it. 1000 ms is once a second
#define LOG_INTERVAL 10 // mills between entries (reduce to take more/faster data)
// how many milliseconds before writing the logged data permanently to disk
// set it to the LOG_INTERVAL to write each time (safest)
// set it to 10*LOG_INTERVAL to write all data every 10 datareads, you could lose up to
// the last 10 reads if power is lost but it uses less power and is much faster!
#define SYNC_INTERVAL 500*LOG_INTERVAL // mills between calls to flush() - to write data to the card
uint32_t syncTime = 0; // time of last sync()
#define ECHO_TO_SERIAL 0 // echo data to serial port (set to 0 to turn off which should increase speed)
#define WAIT_TO_START 0 // Wait for serial input in setup()
// the digital pins that connect to the LEDs
#define redLEDpin 2
#define greenLEDpin 3
//#define BANDGAPREF 14 // special indicator that we want to measure the bandgap
//#define aref_voltage 3.3 // we tie 3.3V to ARef and measure it with a multimeter!
//#define bandgap_voltage 1.1 // this is not super guaranteed but its not -too- off
RTC_DS1307 RTC; // define the Real Time Clock object
// for the data logging shield, we use digital pin 10 for the SD cs line
const int chipSelect = 10;
// the logging file
File logfile;
void error(char *str)
Serial.print("error: ");
Serial.println(str);
// red LED indicates error
digitalWrite(redLEDpin, HIGH);
while (1);
void setup(void)
////////// ZERO LOAD CELLS ///////////////////////////////////////////
leftloadcell.set_scale();
leftloadcell.tare(); //Reset left load cell to zero
// rightloadcell.set_scale();
// rightloadcell.tare(); //Reset left load cell to zero
Serial.println();
// use debugging LEDs
pinMode(redLEDpin, OUTPUT);
pinMode(greenLEDpin, OUTPUT);
#if WAIT_TO_START
Serial.println("Type any character to start");
while (!Serial.available());
#endif //WAIT_TO_START
// initialize the SD card
Serial.print("Initializing SD card...");
// make sure that the default chip select pin is set to
// output, even if you don't use it:
pinMode(10, OUTPUT);
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
error("Card failed, or not present");
Serial.println("card initialized.");
// create a new file
char filename[] = "LOGGER00.CSV";
for (uint8_t i = 0; i < 100; i++) {
filename[6] = i / 10 + '0';
filename[7] = i % 10 + '0';
if (! SD.exists(filename)) {
// only open a new file if it doesn't exist
logfile = SD.open(filename, FILE_WRITE);
break; // leave the loop!
if (! logfile) {
error("couldnt create file");
Serial.print("Logging to: ");
Serial.println(filename);
// connect to RTC
Wire.begin();
if (!RTC.begin()) {
logfile.println("RTC failed");
#if ECHO_TO_SERIAL
Serial.println("RTC failed");
#endif //ECHO_TO_SERIAL
logfile.println("millis,leftpoleforce,rightpoleforce");
#if ECHO_TO_SERIAL
Serial.println("millis,leftpoleforce,rightpoleforce");
// // If you want to set the aref to something other than 5v
// analogReference(EXTERNAL);
void loop(void)
///////// Set Load Cells to Cal factor determined in setup code ///////////////////
leftloadcell.set_scale(calibration_factor); //Adjust to this calibration factor
//rightloadcell.set_scale(calibration_factor); //Adjust to this calibration factor
// DateTime now;
// delay for the amount of time we want between readings
delay((LOG_INTERVAL - 1) - (millis() % LOG_INTERVAL));
digitalWrite(greenLEDpin, HIGH);
// log milliseconds since starting
uint32_t m = millis();
logfile.print(m); // milliseconds since start
logfile.print(", ");
#if ECHO_TO_SERIAL
Serial.print(m); // milliseconds since start
Serial.print(", ");
#endif
// // fetch the time
// now = RTC.now();
// // log time
// logfile.print(now.unixtime()); // seconds since 1/1/1970
// logfile.print(", ");
// logfile.print('"');
// logfile.print(now.year(), DEC);
// logfile.print("/");
// logfile.print(now.month(), DEC);
// logfile.print(now.day(), DEC);
// logfile.print(" ");
// logfile.print(now.hour(), DEC);
// logfile.print(":");
// logfile.print(now.minute(), DEC);
// logfile.print(now.second(), DEC);
//#if ECHO_TO_SERIAL
// Serial.print(now.unixtime()); // seconds since 1/1/1970
// Serial.print(", ");
// Serial.print('"');
// Serial.print(now.year(), DEC);
// Serial.print("/");
// Serial.print(now.month(), DEC);
// Serial.print(now.day(), DEC);
// Serial.print(" ");
// Serial.print(now.hour(), DEC);
// Serial.print(":");
// Serial.print(now.minute(), DEC);
// Serial.print(now.second(), DEC);
//#endif //ECHO_TO_SERIAL
logfile.print(leftloadcell.get_units(), 1);
logfile.print("right pole load");
logfile.println();
#if ECHO_TO_SERIAL
Serial.print(leftloadcell.get_units(), 1);
Serial.print(", ");
Serial.print("right pole load");
Serial.println();
// Log the estimated 'VCC' voltage by measuring the internal 1.1v ref
//analogRead(BANDGAPREF);
//delay(10);
//int refReading = analogRead(BANDGAPREF);
//float supplyvoltage = (bandgap_voltage * 1024) / refReading;
// logfile.print(supplyvoltage);
#if ECHO_TO_SERIAL
// Serial.print(supplyvoltage);
#endif // ECHO_TO_SERIAL
// logfile.println();
// #if ECHO_TO_SERIAL
// Serial.println();
// #endif // ECHO_TO_SERIAL
digitalWrite(greenLEDpin, LOW);
// Now we write data to disk! Don't sync too often - requires 2048 bytes of I/O to SD card
// which uses a bunch of power and takes time
if ((millis() - syncTime) < SYNC_INTERVAL) return;
syncTime = millis();
// blink LED to show we are syncing data to the card & updating FAT!
logfile.flush();
digitalWrite(redLEDpin, LOW);
tension compression load cell FL25.pdf (73.2 KB)
