I am trying to made this project(http://www.instructables.com/id/Pressure-Sensor-Matrix/ ) and using arduino library on processing (firmata) for serial communication. For this project, it requires a pull-up resistor which arduino analog pins also have and need to be enabled with code, while I tried a lot of times it's still not working. I am wondering is the arduino library on processing capable for enable pull-up resistor? Has anyone done that before?
my sensor is connected to 5v on one end, and on the other is gnd and A0
I upload standardFirmata to Arduino. Here is my processing code:
import cc.arduino.*;
import org.firmata.*;
import processing.serial.*;
Arduino arduino;
int A1;
int A2;
size(800, 500);
arduino = new Arduino(this, Arduino.list()[1], 57600);
arduino.pinMode(A1, Arduino.INPUT_PULLUP);
arduino.pinMode(A2, Arduino.INPUT_PULLUP);
void draw() {
background(255);
stroke(0);
if (arduino.analogRead(A1)!=0) {
rect(150, 100, 100, 300);
fill(#BFA4E5);
if (arduino.analogRead(A2)!=0) {
rect(250, 100, 100, 300);
fill(#BFA4E5);
