@pete: thanks for another tip
@cody: i grew tired of being in blind, so i got me multimeter which can measure freq, ut61e.
i am measuring frequency and duty cycle on the pin 10 of arduino micro.
the duty cycle would be 50% when ok, ~25% on failure.
there is another pwm mode, which instead of ICR1 uses OCR1A for top, setting frequency.
in this case not only duty cycle, but also the frequency would be affected by the truncated register.
(easier to measure, if you can not measure duty)
but i assume even without external measuring, if i had read TCCR1B after setting it, i would get a mismatch, which i could indicate via serial or blinking led.
(but that is just my assumption, i have not tried that)
------ this works ------
#include <avr/io.h>
#include <util/delay.h>
#define BLINK_DELAY_MS 500
int main (void)
/* set most pins for output*/
DDRC = 0xFF;
DDRB = 0xFF;
ICR1 = 999; //freq
OCR1B = 500; //duty
TCCR1A = 0;
TCCR1B = 0;
TCCR1A |= _BV(WGM11);
TCCR1B |= _BV(WGM12) | _BV(WGM13);
//Clear OCnA/OCnB/OCnC on compare match when up-counting. Set OCnA/OCnB/OCnC on compare match when down-counting.
TCCR1A |= _BV(COM1B1);
//prescake 1x
TCCR1B |= _BV(CS10);
//disable all timer1 inreupts, not needed, just to be sure
TIMSK1 = 0;
while(1) {
/* set pin 5 high to turn led on */
//PORTB |= _BV(PORTB5);
_delay_ms(BLINK_DELAY_MS);
PORTC ^= 0xFF;
/* set pin 5 low to turn led off */
//PORTB &= ~_BV(PORTB5);
--------- end ----------
----- this fails ------
DDRC = 0xFF;
DDRB = 0xFF;
ICR1 = 999;
OCR1B = 500;
TCCR1A = 0;
TCCR1B = 0;
//FastPWM ICRA = TOP
//TCCR1A |= _BV(WGM11) | _BV(WGM10);
//prescake 1x
TIMSK1 = 0;
----- end ---------
------ this works again ----
DDRC = 0xFF;
DDRB = 0xFF;
OCR1BH = 1;
ICR1 = 999;
OCR1BL = 244;
TCCR1A = 0;
TCCR1B = 0;
//prescake 1x
TIMSK1 = 0;
------ end ------
