Hello everybody,
I'm a beginner in Arduino and I need for a school project to send data from Python to Arduino. So I decided to do it with the SrerialSoftwrae, but the main problem is that I have to send a various number of character (from 5 to 1700+). Sending 5 characters is something very easy, but sending more than 1700 characters is more difficult (the Arduino buffer size is set to 64 bytes, and every char = 1byte). So, what I did is to divide the main string in multiple character strings into the Python program. Then I have to send the 30 "packets" (every single one composed of 64 char),every 150ms to the Arduino via Serial.
But the thing is that it doesn't work and I've searched a solution for hours without finding it...
So if someone more qualified than me could tell me a way to do it without using serial, or what's wrong in my program, I would be very grateful !
The python communication part program (c is the main string) and for the delay, each 0.0000 will corresponds to 150ms :
c1 = len(c)
c2 = c[(63*0):(63*1)] #paquet 1 etc..
c3 = c[(63*1):(63*2)]
c4 = c[(63*2):(63*3)]
c5 = c[(63*3):(63*4)]
c6 = c[(63*4):(63*5)]
c7 = c[(63*5):(63*6)]
c8 = c[(63*6):(63*7)]
c9 = c[(63*7):(63*8)]
c10 = c[(63*8):(63*9)]
c11 = c[(63*9):(63*10)]
c12 = c[(63*10):(63*11)]
c13 = c[(63*11):(63*12)]
c14 = c[(63*12):(63*13)]
c15 = c[(63*13):(63*14)]
c16 = c[(63*14):(63*15)]
c17 = c[(63*15):(63*16)]
c18 = c[(63*16):(63*17)]
c19 = c[(63*17):(63*18)]
c20 = c[(63*18):(63*19)]
c21 = c[(63*19):(63*20)]
c22 = c[(63*20):(63*21)]
c23 = c[(63*21):(63*22)]
c24 = c[(63*22):(63*23)]
c25 = c[(63*23):(63*24)]
c26 = c[(63*24):(63*25)]
c27 = c[(63*25):(63*26)]
c28 = c[(63*26):(63*27)]
c29 = c[(63*27):(63*28)]
print(c1)
str.encode(c)
int1 = 0
str1 = ""
str2 = ""
ports = list(serial.tools.list_ports.comports())
for p in ports:
print (p) # This causes each port's information to be printed out.
# To search this p data, use p[1].
while int1 < 9: # Loop checks "COM0" to "COM8" for Adruino Port Info.
if "Arduino" in p[1]: # Looks for "CH340" in P[1].
str2 = str(int1) # Converts an Integer to a String, allowing:
str1 = "COM" + str2 # add the strings together.
if "Arduino" in p[1] and str1 in p[1]: # Looks for "CH340" and "COM#"
print ("Found Arduino on " + str1)
int1 = 9 # Causes loop to end.
if int1 == 8:
print ("Arduino not found!")
sys.exit() # Terminates Script.
int1 = int1 + 1
c1 = str(c1)
ser = serial.Serial()
ser.port = str1
ser.baudrate = 9600
ser.timeout = 10
ser.close()
ser.open()
time.sleep(2)
ser.write(c1.encode('utf-8'))
time.sleep(0.0000)
ser.write(c2.encode('utf-8'))
time.sleep(0.0000)
ser.write(c3.encode('utf-8'))
time.sleep(0.0000)
ser.write(c4.encode('utf-8'))
time.sleep(0.0000)
ser.write(c5.encode('utf-8'))
time.sleep(0.0000)
ser.write(c6.encode('utf-8'))
time.sleep(0.0000)
ser.write(c7.encode('utf-8'))
time.sleep(0.0000)
ser.write(c8.encode('utf-8'))
time.sleep(0.0000)
ser.write(c9.encode('utf-8'))
time.sleep(0.0000)
ser.write(c10.encode('utf-8'))
time.sleep(0.0000)
ser.write(c11.encode('utf-8'))
time.sleep(0.0000)
ser.write(c12.encode('utf-8'))
time.sleep(0.0000)
ser.write(c13.encode('utf-8'))
time.sleep(0.0000)
ser.write(c14.encode('utf-8'))
time.sleep(0.0000)
ser.write(c15.encode('utf-8'))
time.sleep(0.0000)
ser.write(c16.encode('utf-8'))
time.sleep(0.0000)
ser.write(c17.encode('utf-8'))
time.sleep(0.0000)
ser.write(c18.encode('utf-8'))
time.sleep(0.0000)
ser.write(c19.encode('utf-8'))
time.sleep(0.0000)
ser.write(c20.encode('utf-8'))
time.sleep(0.0000)
ser.write(c21.encode('utf-8'))
time.sleep(0.0000)
ser.write(c22.encode('utf-8'))
time.sleep(0.0000)
ser.write(c23.encode('utf-8'))
time.sleep(0.0000)
ser.write(c24.encode('utf-8'))
time.sleep(0.0000)
ser.write(c25.encode('utf-8'))
time.sleep(0.0000)
ser.write(c26.encode('utf-8'))
time.sleep(0.0000)
ser.write(c27.encode('utf-8'))
time.sleep(0.0000)
ser.write(c28.encode('utf-8'))
time.sleep(0.0000)
ser.write(c29.encode('utf-8'))
ser.close()
Arduino program :
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <LiquidCrystal.h>
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
int lu = 0;
int donneesALire = Serial.available();
int index = 0;
String test = "";
String serial = "STRINGRAW";
String longueurstr = "";
int longueur = 0;
int currentchar = 0;
String serial1 = "";
String serial2 = "";
String serial3 = "";
String serial4 = "";
String serial5 = "";
String serial6 = "";
String serial7 = "";
String serial8 = "";
String serial9 = "";
String serial10 = "";
String serial11 = "";
String serial12 = "";
String serial13 = "";
String serial14 = "";
String serial15 = "";
String serial16 = "";
String serial17 = "";
String serial18 = "";
String serial19 = "";
String serial20 = "";
String serial21 = "";
String serial22 = "";
String serial23 = "";
String serial24 = "";
String serial25 = "";
String serial26 = "";
String serial27 = "";
String serial28 = "";
String serial29 = "";
Serial.println("Ecrivez votre texte");
lcd.begin(16, 2);
lcd.print("On imprime :");
lcd.setCursor(0, 1);
if ((donneesALire > 0) and (lu == 0) and (longueur<=currentchar)
longueurstr=Serial.readString();
longueur = longueurstr.toInt() ;
delay(150.00000);
delay(150.00000/2);
serial1 =Serial.readString();
delay(150.00000);
currentchar = currentchar + 64;
serial2 =Serial.readString();
delay(150.00000);
serial3 =Serial.readString();
delay(150.00000);
serial4 =Serial.readString();
delay(150.00000);
[....] --> exactly the same code for all the strings
serial29 =Serial.readString();
delay(150.00000);
lu = 1;
serial = serial1 + serial2 + serial3 + serial4 + serial5 + serial6 + serial7 +serial8 +serial9 + serial10 + serial11 + serial12 +serial13 +serial14 +serial15 +serial16 +serial17 +serial18 +serial19 +serial20 +serial21 +serial22 +serial23 +serial24 +serial25 +serial26 +serial27 +serial28 +serial29 ;
Serial.println(serial);
