Hi all,
I'm working on a little project to control NeoPixels via MIDI (over regular serial USB). I'm using the latest Arduino MIDI Library (v4.3.1). Running on an Arduino Nano.
The data flow is from my DAW (FL Studio on Windows, if anyone cares) through loopMIDI to Hairless MIDI to the Nano.
I've run into an issue where incoming MIDI messages get dropped if too many arrive at one time. Limit seems to be ~4-5 notes - about 15 bytes. This is obviously a problem. (Seems to be a theme on the forum?)
Hairless MIDI shows all the MIDI messages going out, so the outgoing data is OK.
I've tried everything I can think of, based on forums posts I've read plus my own intuition.
This includes:
- Using HardwareSerial and not SoftwareSerial
- Increasing the RX buffer size as high as 1024 in HardwareSerial.h
- Increasing the baud rate to 115200 in midiSettings.h
- Tried both true/false for Use1ByteParsing in midiSettings.h - no effect either way
- Made the handling code as lean as possible
- Changing the optimization in platforms.txt to -O3 (optimize for speed), confirmed in the compiler output
I can get it to work by staggering the notes slightly in FL, but that's hardly ideal. It also drops data if I send any non-trivial stream of CCs.
Any other suggestions, or obvious errors in my approach? I can't believe the Nano can't keep up, it's bursty data but not unreasonable. Like 90 bytes at once if I send 30 notes? Though I might try an 80 MHz ESP8266 (which I think is overkill).
Code:
// Arduino control of NeoPixel strips via MIDI.
#include <MIDI.h> // Use1ByteParsing set to false, and BaudRate set to 115200
#include <HardwareSerial.h> // Increased the buffer size to 1024
#define PIN 2
#define NUM_PIXELS 60
#define CHANNEL_RED 1
#define CHANNEL_GREEN 2
#define CHANNEL_BLUE 3
#define CHANNEL_WHITE 4
#define CC_BRIGHTNESS 74
// Parameter 1 = number of pixels in strip
// Parameter 2 = Arduino pin number (most are valid)
// Parameter 3 = pixel type flags, add together as needed:
// NEO_KHZ800 800 KHz bitstream (most NeoPixel products w/WS2812 LEDs)
// NEO_KHZ400 400 KHz (classic 'v1' (not v2) FLORA pixels, WS2811 drivers)
// NEO_GRB Pixels are wired for GRB bitstream (most NeoPixel products)
// NEO_RGB Pixels are wired for RGB bitstream (v1 FLORA pixels, not v2)
Adafruit_NeoPixel strip = Adafruit_NeoPixel(NUM_PIXELS, PIN, NEO_GRB + NEO_KHZ800);
MIDI_CREATE_DEFAULT_INSTANCE(); // Baud rate needs to be changed to 115200 in midi_Settings.h !!!! Hairless MIDI must match
boolean changed = false;
MIDIsetup();
strip.begin();
PixelRefresh();
// Don't do a heck of a lot here. All the fun stuff is done in the MIDI handlers.
changed = false;
// Call MIDI.read the fastest you can for real-time performance.
MIDI.read();
if (changed)
PixelRefresh();
changed = false;
void MIDIsetup()
// Initiate MIDI communications, listen to all channels
MIDI.begin(MIDI_CHANNEL_OMNI);
// No MIDIThru
MIDI.turnThruOff();
// Connect the functions to the library
MIDI.setHandleNoteOn(HandleNoteOn);
MIDI.setHandleNoteOff(HandleNoteOff);
MIDI.setHandleControlChange(HandleControlChange);
inline void PixelRefresh()
strip.show();
void HandleNoteOn(byte channel, byte note, byte velocity)
// This acts like a NoteOff.
if (velocity == 0)
HandleNoteOff(channel, note, velocity);
return;
byte brightness = velocity << 2; // 0 to 254
uint32_t current_color = strip.getPixelColor(note);
byte red = (current_color >> 16) & 0xFF;
byte green = (current_color >> 8) & 0xFF;
byte blue = (current_color)& 0xFF;
switch (channel)
case CHANNEL_RED:
red = brightness;
case CHANNEL_GREEN:
green = brightness;
case CHANNEL_BLUE:
blue = brightness;
case CHANNEL_WHITE:
red = brightness;
green = brightness;
blue = brightness;
default: // Ignore all others
return;
strip.setPixelColor(note, red, green, blue);
changed = true;
void HandleNoteOff(byte channel, byte note, byte velocity)
switch (channel)
case CHANNEL_RED:
red = 0;
case CHANNEL_GREEN:
green = 0;
case CHANNEL_BLUE:
blue = 0;
case CHANNEL_WHITE:
red = 0;
green = 0;
blue = 0;
return;
changed = true;
void HandleControlChange(byte channel, byte number, byte value)
switch (number)
case CC_BRIGHTNESS:
HandleBrightness(channel, value * 2);
return;
uint32_t HandleBrightness(byte channel, byte brightness)
byte red = 0;
byte green = 0;
byte blue = 0;
switch (channel)
case CHANNEL_RED:
red = brightness;
case CHANNEL_GREEN:
green = brightness;
case CHANNEL_BLUE:
blue = brightness;
case CHANNEL_WHITE:
red = brightness;
green = brightness;
blue = brightness;
return 0;
for (int i = 0; i < NUM_PIXELS; i++)
strip.setPixelColor(i, red, green, blue);
changed = true;
// EOF
