Hello Everyone,
I have one question refer to UART signal on Arduino.
Now I am trying to use Arduino as just USB-UART converter.
Serial command is sent to external device from Agilent VISA via Arduino.
I made following code on VBA with Agilent VISA and send "1" as test.
Monitoring Arduino Pin0 (RX) and Pin1 (TX) like as attached but signal is appearing on Pin0 (RX).
( I guess signal might appear on Pin1 (TX) )
I am wondering this phenomena is correct or not.
If it's strange, is there any way to improve it ?
Sorry for your time but could you help to give me some advise.
'''''''''''''''''''''' VBA code with Agilent VISA '''''''''''''''''''''''''''''''''
Private Declare PtrSafe Sub Sleep Lib "kernel32" (ByVal dwMilliseconds As Long) 'declare to use "sleep"
Dim RM As New VisaComLib.ResourceManager
Dim CD As New VisaComLib.FormattedIO488 'Arduino UNO
Dim IA As VisaComLib.ISerial
Private Sub CommandButton1_Click()
Set CD.IO = RM.Open("ASRL39::INSTR") 'Opening port
CD.IO.TerminationCharacterEnabled = False 'EOT dis-abled
Set IA = CD.IO
Sleep (100)
IA.Flush IO_IN_BUF 'clear buffer
Dim intSend(0) As Byte
intSend(0) = &H31
Dim ans As Integer
ans = CD.IO.Write(intSend, 1) 'send 1 byte
End Sub
