hello, i'm trying to make a midi controller using multiple hcsr04, it seems running smoothly when iam using 2 sensors. but when i'm trying add 2 more it's doesnt working properly
here's the code for 2 sensors :
#define trigPin1 2
#define echoPin1 3
#define trigPin2 4
#define echoPin2 5
Serial.begin(38400);
pinMode(trigPin1, OUTPUT);
pinMode(echoPin1, INPUT);
pinMode(trigPin2, OUTPUT);
pinMode(echoPin2, INPUT);
long duration1, distance1;
digitalWrite(trigPin1, LOW);
delayMicroseconds(2);
digitalWrite(trigPin1, HIGH);
delayMicroseconds(10);
duration1 = pulseIn(echoPin1, HIGH);
distance1 = (duration1/2) / 29.1;
long duration2, distance2;
digitalWrite(trigPin2, LOW);
digitalWrite(trigPin2, HIGH);
duration2 = pulseIn(echoPin2, HIGH);
distance2 = (duration2/2) / 29.1;
if( distance1<50)
noteOn(0x90, 0x51, 0x45);
else if( distance1>101){
noteOn(0x90, 0x53, 0x45);
delay(30);
if( distance2<50)
noteOn(0x91, 0x61, 0x46);
else if( distance2>101){
noteOn(0x91, 0x63, 0x46);
delay(30);
void noteOn(int cmd, int pitch, int velocity) {
Serial.write(cmd);
Serial.write(pitch);
Serial.write(velocity);
and here's code for 4 sensor, which is doesnt work properly :
#define trigPin1 2
#define echoPin1 3
#define trigPin2 4
#define echoPin2 5
#define trigPin3 6
#define echoPin3 7
#define trigPin4 8
#define echoPin4 9
pinMode(trigPin3, OUTPUT);
pinMode(echoPin3, INPUT);
pinMode(trigPin4, OUTPUT);
pinMode(echoPin4, INPUT);
long duration3, distance3;
digitalWrite(trigPin3, LOW);
digitalWrite(trigPin3, HIGH);
duration3 = pulseIn(echoPin3, HIGH);
distance3 = (duration3/2) / 29.1;
long duration4, distance4;
digitalWrite(trigPin4, LOW);
digitalWrite(trigPin4, HIGH);
duration4 = pulseIn(echoPin4, HIGH);
distance4 = (duration4/2) / 29.1;
if( distance1<50)
delay(30);
if( distance2<50)
delay(30);
if( distance3<50)
noteOn(0x92, 0x71, 0x47);
else if( distance3>101){
noteOn(0x92, 0x73, 0x47);
delay(30);
if( distance4<50)
noteOn(0x93, 0x81, 0x48);
else if( distance4>101){
noteOn(0x93, 0x83, 0x48);
delay(30);
Serial.write(cmd);
i dont know where's the exact problem, on the 4 sensors code im just add another variable for additional sensors. and i'm planning to using 12 sensors 4 this project.is it power problem or something else?
thanks!
