Stripped out all the calibration code and only left raw readings for Mag, Accel and Gyro
#include <SPI.h>
#include "Wire.h"
#define AK8963_ADDRESS 0x0C
#define AK8963_ST1 0x02
#define AK8963_XOUT_L 0x03
#define AK8963_XOUT_H 0x04
#define AK8963_YOUT_L 0x05
#define AK8963_YOUT_H 0x06
#define AK8963_ZOUT_L 0x07
#define AK8963_ZOUT_H 0x08
#define AK8963_CNTL 0x0A
#define AK8963_ASAX 0x10
#define SMPLRT_DIV 0x19
#define CONFIG 0x1A
#define GYRO_CONFIG 0x1B
#define ACCEL_CONFIG 0x1C
#define ACCEL_CONFIG2 0x1D
#define MOT_DUR 0x20
#define ZMOT_THR 0x21
#define ZRMOT_DUR 0x22
#define INT_PIN_CFG 0x37
#define INT_ENABLE 0x38
#define ACCEL_XOUT_H 0x3B
#define ACCEL_XOUT_L 0x3C
#define ACCEL_YOUT_H 0x3D
#define ACCEL_YOUT_L 0x3E
#define ACCEL_ZOUT_H 0x3F
#define ACCEL_ZOUT_L 0x40
#define TEMP_OUT_H 0x41
#define TEMP_OUT_L 0x42
#define GYRO_XOUT_H 0x43
#define GYRO_XOUT_L 0x44
#define GYRO_YOUT_H 0x45
#define GYRO_YOUT_L 0x46
#define GYRO_ZOUT_H 0x47
#define GYRO_ZOUT_L 0x48
#define PWR_MGMT_1 0x6B
#define WHO_AM_I_MPU9250 0x75
#define XA_OFFSET_H 0x77
#define XA_OFFSET_L 0x78
#define YA_OFFSET_H 0x7A
#define YA_OFFSET_L 0x7B
#define ZA_OFFSET_H 0x7D
#define ZA_OFFSET_L 0x7E
#define ADO 0
#if ADO
#define MPU9250_ADDRESS 0x69
#else
#define MPU9250_ADDRESS 0x68
#endif
enum Ascale {
AFS_2G = 0,
AFS_4G,
AFS_8G,
AFS_16G
enum Gscale {
GFS_250DPS = 0,
GFS_500DPS,
GFS_1000DPS,
GFS_2000DPS
enum Mscale {
MFS_14BITS = 0,
MFS_16BITS
uint8_t Gscale = GFS_250DPS;
uint8_t Ascale = AFS_2G;
uint8_t Mscale = MFS_16BITS;
uint8_t Mmode = 0x02;
float aRes, gRes, mRes;
int intPin = 12;
int myLed = 13;
int16_t accelCount[3];
int16_t gyroCount[3];
int16_t magCount[3];
int16_t tempCount;
float temperature;
float SelfTest[6];
Wire.begin();
TWBR = 24;
initMPU9250();
float magCalibration[3];
initAK8963(magCalibration);
while (1) {
readAccelData(accelCount);
Serial.print("\tX-Axis Accel "); Serial.print(accelCount[0]);
Serial.print("\tY-Axis Accel "); Serial.print(accelCount[1]);
Serial.print("\tZ-Axis Accel "); Serial.print(accelCount[2]);
readGyroData(gyroCount);
Serial.print("\tX-Axis Gyro "); Serial.print(gyroCount[0]);
Serial.print("\tY-Axis Gyro "); Serial.print(gyroCount[1]);
Serial.print("\tZ-Axis Gyro "); Serial.print(gyroCount[2]);
readMagData(magCount);
Serial.print("\tX-Axis Mag "); Serial.print(magCount[0]);
Serial.print("\tY-Axis Mag "); Serial.print(magCount[1]);
Serial.print("\tZ-Axis Mag "); Serial.print(magCount[2]);
tempCount = readTempData();
Serial.print("\tTemperature "); Serial.print(tempCount);
delay(100);
void writeByte(uint8_t address, uint8_t subAddress, uint8_t data)
Wire.beginTransmission(address);
Wire.write(subAddress);
Wire.write(data);
Wire.endTransmission();
uint8_t readByte(uint8_t address, uint8_t subAddress)
uint8_t data;
Wire.endTransmission(false);
Wire.requestFrom(address, (uint8_t) 1);
data = Wire.read();
return data;
void readBytes(uint8_t address, uint8_t subAddress, uint8_t count, uint8_t * dest)
uint8_t i = 0;
Wire.requestFrom(address, count);
while (Wire.available()) {
dest[i++] = Wire.read();
void readAccelData(int16_t * destination)
uint8_t rawData[6];
readBytes(MPU9250_ADDRESS, ACCEL_XOUT_H, 6, &rawData[0]);
destination[0] = ((int16_t)rawData[0] << 8) | rawData[1] ;
destination[1] = ((int16_t)rawData[2] << 8) | rawData[3] ;
destination[2] = ((int16_t)rawData[4] << 8) | rawData[5] ;
void readGyroData(int16_t * destination)
uint8_t rawData[6];
readBytes(MPU9250_ADDRESS, GYRO_XOUT_H, 6, &rawData[0]);
void readMagData(int16_t * destination)
uint8_t rawData[7];
if (readByte(AK8963_ADDRESS, AK8963_ST1) & 0x01) {
readBytes(AK8963_ADDRESS, AK8963_XOUT_L, 7, &rawData[0]);
uint8_t c = rawData[6];
if (!(c & 0x08)) {
destination[0] = ((int16_t)rawData[1] << 8) | rawData[0] ;
destination[1] = ((int16_t)rawData[3] << 8) | rawData[2] ;
destination[2] = ((int16_t)rawData[5] << 8) | rawData[4] ;
int16_t readTempData()
uint8_t rawData[2];
readBytes(MPU9250_ADDRESS, TEMP_OUT_H, 2, &rawData[0]);
return ((int16_t)rawData[0] << 8) | rawData[1] ;
void initAK8963(float * destination)
uint8_t rawData[3];
writeByte(AK8963_ADDRESS, AK8963_CNTL, 0x00);
delay(10);
writeByte(AK8963_ADDRESS, AK8963_CNTL, 0x0F);
delay(10);
readBytes(AK8963_ADDRESS, AK8963_ASAX, 3, &rawData[0]);
destination[0] = (float)(rawData[0] - 128) / 256. + 1.;
destination[1] = (float)(rawData[1] - 128) / 256. + 1.;
destination[2] = (float)(rawData[2] - 128) / 256. + 1.;
delay(10);
writeByte(AK8963_ADDRESS, AK8963_CNTL, Mscale << 4 | Mmode);
delay(10);
void initMPU9250()
writeByte(MPU9250_ADDRESS, PWR_MGMT_1, 0x00);
delay(100);
writeByte(MPU9250_ADDRESS, PWR_MGMT_1, 0x01);
delay(200);
writeByte(MPU9250_ADDRESS, CONFIG, 0x03);
writeByte(MPU9250_ADDRESS, SMPLRT_DIV, 0x04);
uint8_t c = readByte(MPU9250_ADDRESS, GYRO_CONFIG);
writeByte(MPU9250_ADDRESS, GYRO_CONFIG, c & ~0x02);
writeByte(MPU9250_ADDRESS, GYRO_CONFIG, c & ~0x18);
writeByte(MPU9250_ADDRESS, GYRO_CONFIG, c | Gscale << 3);
c = readByte(MPU9250_ADDRESS, ACCEL_CONFIG);
writeByte(MPU9250_ADDRESS, ACCEL_CONFIG, c & ~0x18);
writeByte(MPU9250_ADDRESS, ACCEL_CONFIG, c | Ascale << 3);
c = readByte(MPU9250_ADDRESS, ACCEL_CONFIG2);
writeByte(MPU9250_ADDRESS, ACCEL_CONFIG2, c & ~0x0F);
writeByte(MPU9250_ADDRESS, ACCEL_CONFIG2, c | 0x03);
writeByte(MPU9250_ADDRESS, INT_PIN_CFG, 0x22);
writeByte(MPU9250_ADDRESS, INT_ENABLE, 0x01);
delay(100);
