I am working on a mesh of transceivers connected to arduinos.
To make sure that a given transmission packet is not re-transmitted more than once by a node(when relaying), I am going to use a short list of eight bytes (each packet has a unique identifier of one byte). Each node will keep the last eight IDs of packets it has transmitted to look up to ensure no repetitive transmissions. It would not be a linked list but more like a stack but instead of pushing and popping from the top of a stack, I would be pushing the values on one end and losing them out the other.
i.e. The list is based on a first-in-first-out principle. Simplistically, as each packet received was re-transmitted, I would shuffle each of the entries in the list down one (popping the last one off the list thereby losing it) and put the ID of the new packet on the top of the list.
The problem is that when I receive a packet, I have to sequentially traverse the list (to check that the packet has not been sent before) and then go back again and shuffle all the values down and put the new one on top.
This involves a bit of housekeeping overhead for the list when I would like to be getting back the receiving function to check whether more packets have been received in a busy network.
I pretty sure I can't get away from the sequential checking of the list but I was wondering if anyone has a more efficient way of shuffling the values down the list (or other method of maintaining the list).
