Hello! I am working on developing a weather balloon tracker. I have decided to use APRS because I have my Ham license. To do this, I am starting off by using a pre-made APRS code for the Arduino, and add everything else I need for the project. You can find it here. I am trying to transmit some temperature data live with it. To do this, I am trying to alter the “comment” part of the code inside the locationUpdate() Part of the code by adding a variable inside of it. It keeps giving me an error saying, “initializer fails to determine size of ‘comment’.” My code is below.
// Arduino APRS Tracker (aat) with Arduino Pro Mini 3.3V/8 MHz
// Based on https://github.com/sh123/aprs_tracker
#include <SimpleTimer.h>
#include <TinyGPS.h>
#include <LibAPRS.h>
#include <OneWire.h>
#include <DallasTemperature.h>
// Single shot button
#define BUTTON_PIN 10
// LibAPRS
#define OPEN_SQUELCH false
#define ADC_REFERENCE REF_5V
// Setup for DS18B20 temperature sensor
int insideTemp = 0;
int outsideTemp = 0;
#define ONE_WIRE_BUS 2
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
// APRS settings
char APRS_CALLSIGN[]="KM4VXF";
const int APRS_SSID=5;
char APRS_SYMBOL='>';
// Timer
#define TIMER_DISABLED -1
TinyGPS gps;
float falt = gps.f_altitude();
SimpleTimer timer;
char aprs_update_timer_id = TIMER_DISABLED;
bool send_aprs_update = false;
//long instead of float for latitude and longitude
long lat = 0;
long lon = 0;
int year=0;
byte month=0, day=0, hour=0, minute=0, second=0, hundredths=0;
unsigned long age=0;
// buffer for conversions
#define CONV_BUF_SIZE 16
static char conv_buf[CONV_BUF_SIZE];
Serial1.begin(9600);
sensors.begin();
pinMode(BUTTON_PIN, INPUT_PULLUP);
Serial.println(F("Arduino APRS Tracker"));
//GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCGGA);
//GPS.sendCommand(PMTK_SET_NMEA_UPDATE_1HZ);
//GPS.sendCommand(PGCMD_ANTENNA);
APRS_init(ADC_REFERENCE, OPEN_SQUELCH);
APRS_setCallsign(APRS_CALLSIGN,APRS_SSID);
APRS_setSymbol(APRS_SYMBOL);
aprs_update_timer_id=timer.setInterval(2L*60L*1000L, setAprsUpdateFlag);
bool newData = false;
// For one second we parse GPS data
for (unsigned long start = millis(); millis() - start < 1000;)
while (Serial1.available())
char c = Serial1.read();
// Serial.write(c); // uncomment this line if you want to see the GPS data flowing
if (gps.encode(c)) // Did a new valid sentence come in?
newData = true;
if (newData)
sensors.requestTemperatures();
gps.crack_datetime(&year, &month, &day, &hour, &minute, &second, NULL, &age);
gps.get_position(&lat, &lon, &age);
Serial.print(static_cast<int>(day)); Serial.print("/"); Serial.print(static_cast<int>(month)); Serial.print("/"); Serial.print(year);
Serial.print(" "); Serial.print(static_cast<int>(hour)); Serial.print(":"); Serial.print(static_cast<int>(minute)); Serial.print(":"); Serial.print(static_cast<int>(second));Serial.print(F(" "));
Serial.print(F("LAT="));Serial.print(lat);
Serial.print(F(" LON="));Serial.print(lon);
Serial.print(deg_to_nmea(lat, true));
Serial.print(F("/"));
Serial.println(deg_to_nmea(lon, false));
if (digitalRead(BUTTON_PIN)==0)
while(digitalRead(BUTTON_PIN)==0) {}; //debounce
Serial.println(F("MANUAL UPDATE"));
locationUpdate(DallasTemperature::toFahrenheit(sensors.getTempCByIndex(0)), DallasTemperature::toFahrenheit(sensors.getTempCByIndex(1)), falt);
if (send_aprs_update) {
Serial.println(F("APRS UPDATE"));
locationUpdate(0, 0, 0);
timer.run();
void aprs_msg_callback(struct AX25Msg *msg) {
void locationUpdate(int insideTemp, int outsideTemp, int alt) {
char comment []= ("Arduino APRS Weather Ballon! Inside Temp:"+insideTemp);
APRS_setLat((char*)deg_to_nmea(lat, true));
APRS_setLon((char*)deg_to_nmea(lon, false));
// turn off SoftSerial to stop interrupting tx
Serial1.end();
// TX
APRS_sendLoc(comment, strlen(comment));
// read TX LED pin and wait till TX has finished (PB5) digital write 13 LED_BUILTIN
while(bitRead(PORTB,5));
// start SoftSerial again
** Convert degrees in long format to APRS string format
** DDMM.hhN for latitude and DDDMM.hhW for longitude
** D is degrees, M is minutes and h is hundredths of minutes.
** http://www.aprs.net/vm/DOS/PROTOCOL.HTM
char* deg_to_nmea(long deg, boolean is_lat) {
bool is_negative=0;
if (deg < 0) is_negative=1;
// Use the absolute number for calculation and update the buffer at the end
deg = labs(deg);
unsigned long b = (deg % 1000000UL) * 60UL;
unsigned long a = (deg / 1000000UL) * 100UL + b / 1000000UL;
b = (b % 1000000UL) / 10000UL;
conv_buf[0] = '0';
// in case latitude is a 3 digit number (degrees in long format)
if( a > 9999) { snprintf(conv_buf , 6, "%04u", a);} else snprintf(conv_buf + 1, 5, "%04u", a);
conv_buf[5] = '.';
snprintf(conv_buf + 6, 3, "%02u", b);
conv_buf[9] = '\0';
if (is_lat) {
if (is_negative) {conv_buf[8]='S';}
else conv_buf[8]='N';
return conv_buf+1;
// conv_buf +1 because we want to omit the leading zero
else {
if (is_negative) {conv_buf[8]='W';}
else conv_buf[8]='E';
return conv_buf;
void setAprsUpdateFlag() {
send_aprs_update = true;
Any help would be great.
Thank You,
Noah (KM4VXF)
