GSM shield loop problem
i'm working on gsm 900 module. i want to send dynamic value of temperature sensor to cloud server i got problem as " data goes in to cloud server database but loop executes only once,
after one iteration of loop it data goes in to database and program execution stops at url "
i have attached snap shots of command window and code
#include <SoftwareSerial.h>
#include <dht.h>
dht DHT13;  // pin no D13
#define DHT11_PIN13 13 //pin no (digital)
SoftwareSerial mySerial(2, 3); // RX, TX
int8_t answer;
char buff[105];  //to store the url string
char sBuff[100];  //to store the sensor parameters which appends to url string
char id_wasp;
int voltage13t = 0;
int sensor = 0;
int frame_number;
char data[512];
int data_size;
char aux_str[100];
char aux;
int x = 0;
//int frame_no = 0;
void setup(){
//    pinMode(onModulePin, OUTPUT);
      mySerial.begin(9600);
    Serial.println("Starting...");
  //  power_on();
    delay(3000);
     mySerial.println("AT");
  //MODEM  answer =  sendATcommand("AT+SAPBR=0,1", "OK", 20000);
 answer = sendATcommand("AT","OK", 2000);
    while (sendATcommand2("AT+CREG?", "+CREG: 0,1", "+CREG: 0,5", 2000) == 0);
    sendATcommand("AT+SAPBR=3,1,\"Contype\",\"GPRS\"", "OK", 2000);
    sendATcommand("AT+SAPBR=3,1,\"APN\",\"airtelgprs.com\"", "OK", 2000);
 sendATcommand("AT+SAPBR=2,1,\"Contype\",\"GPRS\"", "OK", 2000);
    while (sendATcommand("AT+SAPBR=1,1", "OK", 20000) == 0)
        delay(2000);
    // Initializes HTTP service
    answer = sendATcommand("AT+HTTPINIT", "OK", 10000);
 // Sets CID parameter
        answer = sendATcommand("AT+HTTPPARA=\"CID\",1", "OK", 5000);
  Serial.flush();  //Clear input buffer
   Serial.println("DONE...");
void loop(){
 Serial.println("Entering loop()");
   //reading DHTs
int chk13 = DHT13.read11(DHT11_PIN13);
//dht11 values
float voltage13t = (float)DHT13.temperature;
float voltage13h = (float)DHT13.humidity;
Serial.print("temp:");
Serial.println(voltage13t);
frame_no = frame_no + 1;
frame_no = frame_no % 256;
Serial.print("frame-no:");
Serial.println(frame_no);
  char id_wasp[5]="test";
  char frame_number[3]="ab";
  char sensor[5]="temp";
  //int value= 123;
  //Store the query string in buff
  sprintf(buff, "xx.xx.xxx.xx/connget7.php?");
  sprintf(sBuff,"id_wasp=%s&frame_number=%s&sensor=%s&value=%d.%02d", id_wasp, frame_number, sensor, (int)voltage13t, (int)(voltage13t*100)%100);
   //Concatenate sBuff and buff and store in buff
  strcat(buff, sBuff);
    delay(100);
      char url[130];
      sprintf(url, "AT+HTTPPARA=\"URL\",\"%s\"", buff);
      Serial.println("xx.xx.xxx.xx/connget7.php?id_wasp=test&frame_number=ab&sensor=temp&value=0.00");
     // Sets url
      answer = sendATcommand(url, "OK", 5000);
      delay(5000);
      //Clears url buffer
      memset(url, '\0', sizeof(url));
            if (answer == 1)
                // Starts GET action
                answer = sendATcommand("AT+HTTPACTION=0", "+HTTPACTION:0,200", 12000);
               /* if (answer == 1)
                  goto END;
    delay(5000);
     Serial.println("EXITING FROM loop()");
void power_on(){
    uint8_t answer=0;
    // checks if the module is started
    answer = sendATcommand("AT", "OK", 2000);
    if (answer == 0)
        // waits for an answer from the module
        while(answer == 0){
            // Send AT every two seconds and wait for the answer
int8_t sendATcommand(char* ATcommand, char* expected_answer1, unsigned int timeout){
    uint8_t x=0,  answer=0;
    char response[100];
    unsigned long previous;
    memset(response, '\0', 100);    // Initialize the string
    delay(100);
    while( mySerial.available() > 0) mySerial.read();    // Clean the input buffer
    mySerial.println(ATcommand);    // Send the AT command
   //Serial.println(ATcommand);
        x = 0;
    previous = millis();
    // this loop waits for the answer
    do{
        if(mySerial.available() != 0){
            response[x] = mySerial.read();
            Serial.write(response[x]);
            x++;
            // check if the desired answer is in the response of the module
            if (strstr(response, expected_answer1) != NULL)
                answer = 1;
        // Waits for the asnwer with time out
    while((answer == 0) && ((millis() - previous) < timeout));
    return answer;
int8_t sendATcommand2(char* ATcommand, char* expected_answer1,
char* expected_answer2, unsigned int timeout){
    char response[100];
    delay(100);
        x = 0;
    do{
            x++;
            // check if the desired answer 1 is in the response of the module
                answer = 1;
            // check if the desired answer 2 is in the response of the module
            if (strstr(response, expected_answer2) != NULL)
                answer = 2;
    }while((answer == 0) && ((millis() - previous) < timeout));
    return answer;
