Hi all,
Just received 2 Wemos D1 Pro boards. Downloaded and installed the ESP8266 JSON file.
Also installed the OneWire library, and DallasTemperature library. Both from : ESP8266 DS18B20 Sensor Web Server Arduino IDE (Single, Multiple) | Random Nerd Tutorials
Then using the code on the web site, using my own WiFi login details, programmed the first board. Everything worked well, recording temperature on a mini website. Actually, I tried a few different sketches, including WiFiscan etc. All worked okay.
Then i went to program the same Temperature sketch into the 2nd D1Pro. However, now it doesn't work.
Sat for over 10 minutes before I realised that it wasn't going to work.
Tried using the 1st D1 board again, but did not work either.
Turned on Verbose logging. Please see attached. This is the complete log.
I have reinstalled the IDE, but no luck. I cannot see what is wrong in the log.
So people, what has happened? And if more info is required, just ask.
If I've done something wrong please advise.
Arduino Compile error - 2007201.pdf (36.7 KB)
