Estoy haciendo el proyecto de un dispositivo MIDI el cual cuenta con 6 potenciometros, ya busque un código, pero me sale un error al verificar, no se si sea por usar un arduino Leonardo ya que soy nuevo en esto.
El código que completo es este:
// Simple UNTZtrument MIDI step sequencer.
// Requires an Arduino Leonardo w/TeeOnArdu config (or a PJRC Teensy),
// software on host computer for synth or to route to other devices.
#include <Wire.h>
#include <Adafruit_Trellis.h>
#include <Adafruit_UNTZtrument.h>
#include "MIDIUSB.h"
#define LED 13 // Pin for heartbeat LED (shows code is working)
#ifndef HELLA
// A standard UNTZtrument has four Trellises in a 2x2 arrangement
// (8x8 buttons total). addr[] is the I2C address of the upper left,
// upper right, lower left and lower right matrices, respectively,
// assuming an upright orientation, i.e. labels on board are in the
// normal reading direction.
Adafruit_Trellis T[4];
Adafruit_UNTZtrument untztrument(&T[0], &T[1], &T[2], &T[3]);
const uint8_t addr[] = { 0x70, 0x71, 0x72, 0x73 };
#else
// A HELLA UNTZtrument has eight Trellis boards...
Adafruit_Trellis T[8];
Adafruit_UNTZtrument untztrument(&T[0], &T[1], &T[2], &T[3],
&T[4], &T[5], &T[6], &T[7]);
const uint8_t addr[] = { 0x70, 0x71, 0x72, 0x73,
0x74, 0x75, 0x76, 0x77 };
#endif // HELLA
#define WIDTH ((sizeof(T) / sizeof(T[0])) * 2)
#define N_BUTTONS ((sizeof(T) / sizeof(T[0])) * 16)
// Encoder on pins 4,5 sets tempo. Optional, not present in
// standard UNTZtrument, but won't affect things if unconnected.
enc e(4, 5);
uint8_t grid[WIDTH]; // Sequencer state
uint8_t heart = 0, // Heartbeat LED counter
col = WIDTH-1; // Current column
unsigned int bpm = 240; // Tempo
unsigned long beatInterval = 60000L / bpm, // ms/beat
prevBeatTime = 0L, // Column step timer
prevReadTime = 0L; // Keypad polling timer
// The note[] and channel[] tables are the MIDI note and channel numbers
// for to each row (top to bottom); they're specific to this application.
// bitmask[] is for efficient reading/writing bits to the grid[] array.
static const uint8_t PROGMEM
note[8] = { 72, 71, 69, 67, 65, 64, 62, 60 },
channel[8] = { 1, 1, 1, 1, 1, 1, 1, 1 },
bitmask[8] = { 1, 2, 4, 8, 16, 32, 64, 128 };
Serial.begin (31250);//Default speed of MIDI serial port
pinMode(LED,OUTPUT);//Light LED on L to notify of readynes
digitalWrite(LED, HIGH);
#ifndef HELLA
untztrument.begin(addr[0], addr[1], addr[2], addr[3]);
#else
untztrument.begin(addr[0], addr[1], addr[2], addr[3],
addr[4], addr[5], addr[6], addr[7]);
#endif // HELLA
// Default Arduino I2C speed is 100 KHz, but the HT16K33 supports
// 400 KHz. We can force this for faster read & refresh, but may
// break compatibility with other I2C devices...so be prepared to
// comment this out, or save & restore value as needed.
#ifdef ARDUINO_ARCH_SAMD
Wire.setClock(400000L);
#endif
#ifdef __AVR__
TWBR = 12; // 400 KHz I2C on 16 MHz AVR
#endif
untztrument.clear();
untztrument.writeDisplay();
memset(grid, 0, sizeof(grid));
enc::begin(); // Initialize all encoder pins
e.setBounds(60 * 4, 480 * 4 + 3); // Set tempo limits
e.setValue(bpm * 4); // *4's for encoder detents
void noteOn(byte channel, byte pitch, byte velocity) {
midiEventPacket_t noteOn = {0x09, 0x90 | channel, pitch, velocity};
MidiUSB.sendMIDI(noteOn);
MidiUSB.flush();
void noteOff(byte channel, byte pitch, byte velocity) {
midiEventPacket_t noteOff = {0x08, 0x80 | channel, pitch, velocity};
MidiUSB.sendMIDI(noteOff);
MidiUSB.flush();
// Turn on (or off) one column of the display
void line(uint8_t x, boolean set) {
for(uint8_t mask=1, y=0; y<8; y++, mask <<= 1) {
uint8_t i = untztrument.xy2i(x, y);
if(set || (grid[x] & mask)) untztrument.setLED(i);
else untztrument.clrLED(i);
int iAn0Val=0;
int iAn1Val=0;
int iAn2Val=0;
int iAn3Val=0;
int iAn4Val=0;
int iAn5Val=0;
//Canal1
int iAn0ValPrev = iAn0Val;
iAn0Val = analogRead(A0)/8;
analogPinMidiTX(1,iAn0Val,iAn0ValPrev);
//Canal2
int iAn1ValPrev = iAn1Val;
iAn1Val = analogRead(A1)/8;
analogPinMidiTX(2,iAn1Val,iAn1ValPrev);
//Canal3
int iAn2ValPrev = iAn2Val;
iAn2Val = analogRead(A2)/8;
analogPinMidiTX(3,iAn2Val,iAn2ValPrev);
//Canal4
int iAn3ValPrev = iAn3Val;
iAn3Val = analogRead(A3)/8;
analogPinMidiTX(4,iAn3Val,iAn3ValPrev);
//Canal5
int iAn4ValPrev = iAn4Val;
iAn4Val = analogRead(A4)/8;
analogPinMidiTX(5,iAn4Val,iAn4ValPrev);
//Canal6
int iAn5ValPrev = iAn5Val;
iAn5Val = analogRead(A5)/8;
analogPinMidiTX(6,iAn5Val,iAn5ValPrev);
uint8_t mask;
boolean refresh = false;
unsigned long t = millis();
enc::poll(); // Read encoder(s)
if((t - prevReadTime) >= 20L) { // 20ms = min Trellis poll time
if(untztrument.readSwitches()) { // Button state change?
for(uint8_t i=0; i<N_BUTTONS; i++) { // For each button...
uint8_t x, y;
untztrument.i2xy(i, &x, &y);
mask = pgm_read_byte(&bitmask[y]);
if(untztrument.justPressed(i)) {
if(grid[x] & mask) { // Already set? Turn off...
grid[x] &= ~mask;
noteOff(pgm_read_byte(&channel[y]), pgm_read_byte(¬e[y]), 127);
} else { // Turn on
grid[x] |= mask;
refresh = true;
prevReadTime = t;
digitalWrite(LED, ++heart & 32); // Blink = alive
if((t - prevBeatTime) >= beatInterval) { // Next beat?
// Turn off old column
line(col, false);
for(uint8_t row=0, mask=1; row<8; row++, mask <<= 1) {
if(grid[col] & mask) {
noteOff(pgm_read_byte(&channel[row]), pgm_read_byte(¬e[row]), 127);
// Advance column counter, wrap around
if(++col >= WIDTH) col = 0;
// Turn on new column
line(col, true);
noteOn(pgm_read_byte(&channel[row]), pgm_read_byte(¬e[row]), 127);
prevBeatTime = t;
refresh = true;
bpm = e.getValue() / 4; // Div for encoder detents
beatInterval = 60000L / bpm;
if(refresh) untztrument.writeDisplay();
void analogPinMidiTX(int iChan, int iVal, int iValPrev)
if (iValPrev !=iVal)
MidiTX(0, iChan, iValPrev);
MidiTX(0x64, iChan,iVal);
void MidiTX(unsigned char VELOCITY, unsigned char CANAL, unsigned char VALOR)//pass values out through standard Midi Command
CANAL += 0X90 - 1;
Serial.write(CANAL);
Serial.write(VALOR);
Serial.write(VELOCITY);
Y el código que cargue de referencia es este:
Serial.begin(31250); // Default speed of MIDI serial port
pinMode(13, OUTPUT); // Light LED on pin 13 to notify of readynes
digitalWrite(13, HIGH);
int iAn0Val=0;
int iAn1Val=0;
int iAn2Val=0;
int iAn3Val=0;
int iAn4Val=0;
iAn0Val = analogRead(0)/8;
//2
iAn1Val = analogRead(1)/8;
//3
iAn2Val = analogRead(2)/8;
//4
iAn3Val = analogRead(3)/8;
//5
iAn4Val = analogRead(4)/8;
//only TX the value over midi if it is changed, as to prevent spamming the midi port and thus confusing the receiving application in learning mode
if(iValPrev != iVal)
MidiTX(176,iChan,iVal);
void MidiTX(unsigned char MESSAGE, unsigned char CONTROL, unsigned char VALUE) //pass values out through standard Midi Command
Serial.print(MESSAGE);
Serial.print(CONTROL);
Serial.print(VALUE);
Muchas gracias, para el que me pueda ayudar con este problema.
