I tried the following code to implement a watchdog timer:
void watchdog_setup(void){
// Set up the generic clock (GCLK2) used to clock the watchdog timer at 1.024kHz
REG_GCLK_GENDIV = GCLK_GENDIV_DIV(4) | // Divide the 32.768kHz clock source by divisor 32, where 2^(4 + 1): 32.768kHz/32=1.024kHz
GCLK_GENDIV_ID(2); // Select Generic Clock (GCLK) 2
while (GCLK->STATUS.bit.SYNCBUSY); // Wait for synchronization
REG_GCLK_GENCTRL = GCLK_GENCTRL_DIVSEL | // Set to divide by 2^(GCLK_GENDIV_DIV(4) + 1)
GCLK_GENCTRL_IDC | // Set the duty cycle to 50/50 HIGH/LOW
GCLK_GENCTRL_GENEN | // Enable GCLK2
GCLK_GENCTRL_SRC_OSCULP32K | // Set the clock source to the ultra low power oscillator (OSCULP32K)
GCLK_GENCTRL_ID(2); // Select GCLK2
// Feed GCLK2 to WDT (Watchdog Timer)
REG_GCLK_CLKCTRL = GCLK_CLKCTRL_CLKEN | // Enable GCLK2 to the WDT
GCLK_CLKCTRL_GEN_GCLK2 | // Select GCLK2
GCLK_CLKCTRL_ID_WDT; // Feed the GCLK2 to the WDT
REG_WDT_CONFIG = WDT_CONFIG_PER_1K; // Set the WDT reset timeout to 16 seconds
while(WDT->STATUS.bit.SYNCBUSY); // Wait for synchronization
REG_WDT_CTRL = WDT_CTRL_ENABLE; // Enable the WDT in normal mode
void watchdog_clear(void){
if (!WDT->STATUS.bit.SYNCBUSY) // Check if the WDT registers are synchronized
REG_WDT_CLEAR = WDT_CLEAR_CLEAR_KEY; // Clear the watchdog timer
I added watchdog_setup() to my setup function, but I never receive any resets. I also tried the WDTZero library on github but that also didn't reset the MKR GSM 1400.
Any reason why watchdog code for the MKRZero wouldn't work on the MKR GSM 1400? Is there watchdog code out there that does work?
