Hi all
I'm working on a project to automate a machine using arduino. I have temparature sensors,flow meters and rpm sensors to be read and also i need to control a few switches using arduino.
It will be great if there is an interfacing software to view the live data feed from those sensors and switches to control those relays from a pc which is connected to the arduino via a wifi/ethernet.
note: We have arduino friendly app to control these functions, what i need a software on our pc to do the same.
Makerplot is a user configurable interface, that works on windows OS XP, Vista, 7 and 8.1. The learning curve is kind of steep, but it has a pretty good PDF manual. Some of the necessary functions aren't outlined in the manual however, but the designer Martin is super helpful.
I have successfully used this interface to do precisely what you are looking for.
Proview
Open Source Software for Linux. Can work with Arduino. proview.se
Windows Forms
Interface for making GUIs. Part of the Microsoft .NET Framework. Wikipedia: Windows Forms
KODA FromDesigner
A standalone application that was developed to help creating forms (GUIs) for AutoIt3 scripting language. koda.darkhost.ru
SerialComInstruments
Display and visualize data from serial. Control microcontroller via serial port. serialcominstruments.com/instrument.php (Website in German language.)
Arduino Dashboard
PC frontend for the Arduino. It provides controls that usually take along time to build on a breadboard. mathias-wilhelm.de: arduino-dashboard (English)
Proview
Windows Forms
KODA FromDesigner
Arduino Dashboard
I've made an environment for Arduino/visual studio to create finite state machines and present & control the I/O on a PC via a serial connection. It is now also possible to make trends and log I/O in an access database. See also my website www.jbsiemonsma.nl
JelleSiemonsma:
Ok. Is that a source code available or i can get it as a software?
Look in the website under "visual studio repository". There is a zip file named "example 17-02-13". It contains the sketch and the vs application. Available until coming friday. Click on the button "details" for info regarding the zip file. Succes!
No, only by serial connection and by wifi. For the wifi option, a esp8266 is connected to the MEGA board and via a router connected to a windows pc. For serial a bleutooth, serial to usb, or a radio connection (like apc220) can be used on serial1.
Python Banyan uses the LAN as a software backplane, so you can have the GUI running on one machine and the Arduino control software running on another.
