I want to minimize latency, and maximize actual through put to some IO, without too much overhead or complexity. The primary option is SPI with DMA, but as the target IO is only accessed in blocks a few bytes long (~3 to 5) it seems this option will create more overhead and complexity than it saves. The next solution is some “Byte Bashing”, or make a basic 8 bit parallel port. After looking through the Data Sheet, and the Arduino Zero Schematic, and lots of posts, I have made a list of PINS, and how they correlate to the Zero's “GPIO”. Looking at the list, it seems there are possibly two solid bytes of IO, and a further hand full for other functions. I have modified port.h such that PORT_(IN/OUT)_Type has an extra member of four uint8_t's in the union, allowing access to each byte. According to the data sheet these registers can be accessed and modified in bytes. I then read/write these bytes. It seems to work. It seems to generate about 4-5M read/write cycles per second. The program does seem to copy the data from the B Byte to the C Byte. (Extremely short on jumpers at the moment.) The LED toggles when I short the appropriate input
So any opinions on this? Is there a way to see the assembly code to make sure it is really doing byte access, not some crazy tricks. Is there a faster/simpler way to do this?
Pin List
A0 - PORT_PA02
AREF - PORT_PA03
A3 - PORT_PA04
A4 - PORT_PA05
D8 - PORT_PA06
D9 – PORT_PA07
D4 - PORT_PA08
D3 - PORT_PA09
D1 – PORT_PA10
D0 - PORT_PA11
MISO - PORT_PA12
ATN - PORT_PA13
D2 - PORT_PA14
D5 – PORT_PA15
D11 - PORT_PA16
D13 - PORT_PA17
D10 - PORT_PA18
D12 - PORT_PA19
D6 - PORT_PA20
D7 – PORT_PA21
SDA – PORT_PA22 (Note Pull Up Res)
SCL – PORT_PA23 (Note Pull Up Res)
A5 - PORT_PB02
A1 - PORT_PB08
A2 - PORT_PB09
MOSI - PORT_PB10
SCK - PORT_PB11
..\packages\arduino\tools\CMSIS\4.0.0-atmel\Device\ATMEL\samd21\include\component\port.h
typedef union {
struct {
uint32_t OUT:32; /*!< bit: 0..31 Port Data Output Value /
} bit; /!< Structure used for bit access /
struct {
uint8_t A;
uint8_t B;
uint8_t C;
uint8_t D;
} my_byte; /!< Structure used for byte access */
uint32_t reg; /*!< Type used for register access */
} PORT_OUT_Type;
typedef union {
struct {
uint32_t IN:32; /*!< bit: 0..31 Port Data Input Value /
struct {
uint8_t A;
uint8_t B;
uint8_t C;
uint8_t D;
} my_byte; /!< Structure used for byte access /
uint32_t reg; /!< Type used for register access */
} PORT_IN_Type;
Byte Bashing
int i;
// the setup function runs once when you press reset or power the board
// initialize serial communication at 9600 bits per second:
pinMode(4, INPUT_PULLUP);
pinMode(3, INPUT_PULLUP);
pinMode(1, INPUT_PULLUP);
pinMode(0, INPUT_PULLUP);
pinMode(MISO, INPUT_PULLUP);
pinMode(ATN, INPUT_PULLUP);
pinMode(2, INPUT_PULLUP);
pinMode(5, INPUT_PULLUP);
pinMode(11, OUTPUT);
pinMode(13, OUTPUT);
pinMode(10, OUTPUT);
pinMode(12, OUTPUT);
pinMode(6, OUTPUT);
pinMode(7, OUTPUT);
// pinMode(SDA, OUTPUT);// (Note Pull Up Res)
// pinMode(SCL, OUTPUT);// (Note Pull Up Res)
// the loop function runs over and over again forever
for (i = 0; i < 1000000; i++)
PORT->Group[PORTA].OUT.my_byte.C = PORT->Group[PORTA].IN.my_byte.B;
Serial.println("10 Million!");
