Can anyone else get this code to work? if it does, then I have faulty equipment.
// 20x4 Subscriber Counter for YouTube //
// http://www.educ8s.tv //
#include <Wire.h>
#include <ESP8266WiFi.h>
#include <ArduinoJson.h>
byte LT[8] =
B01111,
B11111,
B11111,
B11111,
B11111,
B11111,
B11111,
B11111
byte UB[8] =
B11111,
B11111,
B11111,
B00000,
B00000,
B00000,
B00000,
B00000
byte RT[8] =
B11110,
B11111,
B11111,
B11111,
B11111,
B11111,
B11111,
B11111
byte LL[8] =
B11111,
B11111,
B11111,
B11111,
B11111,
B11111,
B11111,
B01111
byte LB[8] =
B00000,
B00000,
B00000,
B00000,
B00000,
B11111,
B11111,
B11111
byte LR[8] =
B11111,
B11111,
B11111,
B11111,
B11111,
B11111,
B11111,
B11110
byte UMB[8] =
B11111,
B11111,
B11111,
B00000,
B00000,
B00000,
B11111,
B11111
byte LMB[8] =
B11111,
B00000,
B00000,
B00000,
B00000,
B11111,
B11111,
B11111
const char* ssid = ""; // SSID of local network
const char* password = ""; // Password on network
String apiKey = ""; // YouTube Data API v3 key generated here: // https://console.developers.google.com
String channelId = ""; // YouTube channel id
const char *host = "www.googleapis.com";
long subscribers,subscribersBefore = 0;
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE); // Set the LCD I2C address
int cursorPosition=0;
lcd.begin(20,4);
lcd.setCursor(0,0);
lcd.print("Connecting ....");
createCustomChars();
WiFi.begin(ssid, password);
lcd.setCursor(cursorPosition,1);
lcd.print(".");
cursorPosition++;
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Connected to JoeteckTips!");
int length;
String subscribersString = String(getSubscribers());
if(subscribers != subscribersBefore)
lcd.clear();
length = subscribersString.length();
printSubscribers(length,subscribersString);
subscribersBefore = subscribers;
delay(60000);
void printSubscribers(int length, String subscribersString)
switch(length)
case 5: printDigits(subscribersString,5);printDigits(subscribersString,4);printDigits(subscribersString,3);printDigits(subscribersString,2);printDigits(subscribersString,1);break;
case 4: printDigits(subscribersString,4);printDigits(subscribersString,3);printDigits(subscribersString,2);printDigits(subscribersString,1);break;
case 3: printDigits(subscribersString,3);printDigits(subscribersString,2);printDigits(subscribersString,1);break;
case 2: printDigits(subscribersString,2);printDigits(subscribersString,1);break;
case 1: printDigits(subscribersString,1);break;
default: break;
void printDigits(String subscribersString,int digit)
int length = subscribersString.length();
char digitToPrint = subscribersString.charAt(length-digit);
Serial.println(digitToPrint);
switch(digit)
case 1: printDigitToScreen(digitToPrint,17); break;
case 2: printDigitToScreen(digitToPrint,13); break;
case 3: printDigitToScreen(digitToPrint,9); break;
case 4: printDigitToScreen(digitToPrint,5); break;
case 5: printDigitToScreen(digitToPrint,1); break;
void printDigitToScreen(char digit,int position)
int digitToPrint = digit - '0'; //Convertion from char to int
switch(digitToPrint)
case 1:digit1(position); break;
case 2:digit2(position); break;
case 3:digit3(position); break;
case 4:digit4(position); break;
case 5:digit5(position); break;
case 6:digit6(position); break;
case 7:digit7(position); break;
case 8:digit8(position); break;
case 9:digit9(position); break;
case 0:digit0(position); break;
void digit0(int position_x)
lcd.setCursor(position_x, 1);
lcd.write((byte)0);
lcd.write(1);
lcd.write(2);
lcd.setCursor(position_x, 2);
lcd.write(3);
lcd.write(4);
lcd.write(5);
void digit1(int position_x)
lcd.setCursor(position_x,1);
lcd.write(1);
lcd.write(2);
lcd.setCursor(position_x+1,2);
lcd.write(5);
void digit2(int position_x)
lcd.write(6);
lcd.write(6);
lcd.write(2);
lcd.write(3);
lcd.write(7);
lcd.write(7);
void digit3(int position_x)
lcd.write(6);
lcd.write(6);
lcd.write(2);
lcd.setCursor(position_x,2);
lcd.write(7);
lcd.write(7);
lcd.write(5);
void digit4(int position_x)
lcd.write(3);
lcd.write(4);
lcd.write(2);
lcd.setCursor(position_x+2,2);
lcd.write(5);
void digit5(int position_x)
lcd.write((byte)0);
lcd.write(6);
lcd.write(6);
lcd.write(7);
lcd.write(7);
lcd.write(5);
void digit6(int position_x)
lcd.write((byte)0);
lcd.write(6);
lcd.write(6);
lcd.write(3);
lcd.write(7);
lcd.write(5);
void digit7(int position_x)
lcd.write(1);
lcd.write(1);
lcd.write(2);
lcd.write((byte)0);
void digit8(int position_x)
lcd.write((byte)0);
lcd.write((byte)6);
lcd.write(2);
lcd.write(3);
lcd.write(7);
lcd.write(5);
void digit9(int position_x)
lcd.write((byte)0);
lcd.write((byte)6);
lcd.write((byte)2);
lcd.write((byte)5);
int getSubscribers()
WiFiClientSecure client;
Serial.print("connecting to "); Serial.println(host);
if (!client.connect(host, 443)) {
Serial.println("connection failed");
return -1;
String cmd = String("GET /youtube/v3/channels?part=statistics&id=") + channelId + "&key=" + apiKey+ " HTTP/1.1\r\n" +
"Host: " + host + "\r\nUser-Agent: ESP8266/1.1\r\nConnection: close\r\n\r\n";
client.print(cmd);
int repeatCounter = 10;
while (!client.available() && repeatCounter--) {
String line,buf="";
int startJson=0;
while (client.connected() && client.available()) {
line = client.readStringUntil('\n');
if(line[0]=='{') startJson=1;
if(startJson)
for(int i=0;i<line.length();i++)
if(line=='[' || line_==']') line*=' ';
buf+=line+"\n";
client.stop();
DynamicJsonBuffer jsonBuf;
JsonObject &root = jsonBuf.parseObject(buf);
if (!root.success()) {
Serial.println("parseObject() failed");
delay(10);
return -1;
}*_
* subscribers = root["items"]["statistics"]["subscriberCount"];*
* Serial.println(subscribers);*
* return subscribers;*
void createCustomChars()
* lcd.createChar(0,LT);*
* lcd.createChar(1,UB);*
* lcd.createChar(2,RT);*
* lcd.createChar(3,LL);*
* lcd.createChar(4,LB);*
* lcd.createChar(5,LR);*
* lcd.createChar(6,UMB);*
* lcd.createChar(7,LMB);*
