Hello to everyone, first of all, I appologize because this is my first post ever on this forum and I don't speak very good english (and writing is much bad :D)
Let's start with the beginning: I am working to an autonomous car model, witch shoud send to the remote some data, i.e. speed, direction, etc.
I chosed as communication method, two bluetooth modules. With other words, I've done with the technical platform, and now, the beautiful part: software programming..
Well, I decided to use Arduino Mega2560 because of four serial ports, all used:
Port 0, USB, I'll use this for debug and programming, well, this is unused for now.
Port 1, I use for the bluetooth module, so TX and RX.
Port 2, only RX is used: I've chosen two ATTiny85: This, port is used to read the RPM of the car, to later calculate the speed.
Port 3, only TX, the second ATTiny85, witch will control some LEDs. I've chosed to work with 2xATTiny85 because one use some delay() functions, and other to listen only for pulses to calculate the RPM.
Both tiny.s are using SoftwareSerial on pin3.
So good, so far.
After I assembled everything, first test, of RPM.
And here my problem rised:
I've combined 2 default sketches of arduino IDE to control the ESC, and read RPM from the tiny.
#include <Servo.h>
Servo ESC;
int val;
int RPM;
// initialize both serial ports:
Serial2.begin(9600);
pinMode(13, OUTPUT);
ESC.attach(46);
val = analogRead(A0);
val = map(val, 0, 1023, 1000, 2000);
ESC.writeMicroseconds(val);
if (val == 1500)
digitalWrite(13, HIGH);
digitalWrite(13, LOW);
// read from port 1, send to port 0:
if (Serial2.available()) {
int inByte = Serial2.read();
Serial.write(inByte);
// read from port 0, send to port 1:
if (Serial.available()) {
int inByte = Serial.read();
Serial2.write(inByte);
Serial.println(RPM);
If the motor does not rotate, I receive "0" rpm, as exected; but when Arduino starts to send pulse to the ESC (as servo), serial become full of garbage, where I need to reset everything to go back to 0..
I.ve readed many topics where other users said to change the pin of the servo. I've tried all pins that can generate PWM (any timer on Mega) but without succes..
There are any solutions for this issue ?
