Neither of those look suitable for a self-balancing robot. You don't need the hall sensors for a balancing robot. Exactly what kind of balancing? Wheels, legs?
Keep googling. There's hundreds of example projects out there. Copy what they did.
MorganS:
Disagree, seems fine to me.
The hall sensors are on the motor for commutation, its a sensored BLDC which is
simple to drive at full torque at stationary.
The MPU6050 gives 6DoF (at least), although you only perhaps need 1 gyro and 2
accelerometer axes, the convenience of one chip with one library means there's
no reason not to use a full IMU.
That Roboteq controller sounds capable:
Using low-cost position sensors, they may also be set to operate as heavy-duty position servos.
The SBL13xx accepts commands received from an RC radio, Analog Joystick, wireless modem, or microcomputer. Using CAN bus, up to 127 controllers can be networked on a single twisted pair cable. Numerous safety features are incorporated into the controller to ensure reliable and safe operation.
Thank u MarkT!
So i have to emulate from arduino something like rc radio to send pulses to the sbl13-motor to control? Or there is another one way to do?
