hello to all
when i try an example for wifi
arduino tell me that wifi module noit found
i can't upgrade the firmware
how to run the wifi?
thank you
Double click the RESET button to put the board in bootloader upload mode.
not run
The MKR WiFi 1010 comes with its pins inserted into black foam. This foam is electrically conductive so you need to remove it before using the board.
Try running the sketch with no wiring, components, modules, shields, etc. connected to your MKR WiFi 1010.
Make sure the MKR WiFi 1010 isn't sitting on any conductive objects which could short out the pins on the bottom of the board.
thank you
i understand why not download firmware
i mistake in select the card
sorry for english
Thanks for taking the time to post an update with your solution mikibenx! I'm glad to hear you found the problem. Enjoy!
Per
