so i have a code that all functions work now including stopping when nothing is pressed. not sure if this is from the transmitter recever pair im using but it seems theres sometimes as highs as a 2 sec delay between when i send value and when the rx receves the value anyway heres what i have for code working so far tx side first
//BUTTON PINS
const int SW1 = 8; //forward
const int SW2 = 9; //backward
const int SW3 = 3; //left
const int SW4 = 2; //right
//SET BUTTON AS PULLUP
pinMode(SW1, INPUT_PULLUP);
pinMode(SW2, INPUT_PULLUP);
pinMode(SW3, INPUT_PULLUP);
pinMode(SW4, INPUT_PULLUP);
//TRANSMITTER PINS
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
pinMode(7, OUTPUT);
void loop(void)
//sends 15 as stop command if no button pressed
unsigned char i = 15;
//if button pressed - from 15 and send new value
//backwards
if (digitalRead(SW1) == HIGH)
i -= 8;
//forward
if (digitalRead(SW2) == HIGH)
i -= 4;
//left
if (digitalRead(SW3) == HIGH)
i -= 2;
//right
if (digitalRead(SW4) == HIGH)
i -= 1;
send_data(i);
Serial.print("i=");
Serial.println(i, DEC);
send_data(0);
void send_data(unsigned char data)
digitalWrite(4, (data & 0x01));
digitalWrite(5, (data & 0x02));
digitalWrite(6, (data & 0x04));
digitalWrite(7, (data & 0x08));
rx code
#include <Servo.h>
#include <MotorDriver.h>
Servo camera;
int data = 0;
const int rx_led = 42;
//MOTOR SHIELD SET MOTOR SPEEDS
motordriver.init();
motordriver.setSpeed(400, MOTORB);
motordriver.setSpeed(200, MOTORA); // steering motor
//DATA RECIEVE INDICATOR LIGHT
pinMode(rx_led, OUTPUT);
digitalWrite(rx_led, LOW);
//RECIEVER PINS
pinMode(3, INPUT);
pinMode(4, INPUT);
pinMode(5, INPUT);
pinMode(6, INPUT);
pinMode(7, INPUT);
attachInterrupt(1, RF_VT, RISING);
//BEGIN SERIAL COMMUNICATION
//DATA FROM TRANSMITTER TO DETERMINE MOVE FUNCTION
//stop
if (data == 15)
motordriver.stop();
//turn wheels right
else if (data == 14)
motordriver.goRight();
//turn wheels left
else if (data == 13)
motordriver.goLeft();
// move forward
else if (data == 11)
motordriver.goForward();
//move backward
else if (data == 7)
motordriver.goBackward();
//straight left turn
else if (data == 9)
//straight right turn
else if (data == 10)
//back left turn
else if (data == 5)
//back right turn
else if (data == 6)
//SERIAL PRINT DATA RECIEVED
delay(50);
Serial.print("data=");
Serial.println(data, DEC);
void RF_VT() // interrupt service function
data = (digitalRead(4) << 3) + (digitalRead(5) << 2) + (digitalRead(6) << 1) + (digitalRead(7) << 0);
