Help code for Serial Port, Using Words connected to ints
Gonna cut straight to the cheese, im trying to use Serial Port to send commands to my servo, i have it all worked out, but i have to type numbers in.
int IT1 = 120;
Essentially thats what i have, but i have to type in the 120, is there a way to make it so i have to type in "IT1" into the serial port to execute the same command?
You dont have to read the code unless you want to......
#include<Servo.h>
Servo servo1;
const int IT1 = 120;
const int IT2 = 45;
const int IT3 = 0;
int Order = 15;
// Example 4 - Receive a number as text and convert it to an int
const byte numChars = 32;
char receivedChars[numChars];   // an array to store the received data
boolean newData = false;
int dataNumber = 1;  // new for this version
    Serial.println("<Arduino is ready>");
    servo1.attach(4);
    recvWithEndMarker();
    showNewNumber();
        if (dataNumber == IT1){
          servo1.write(IT1);
          servo1.write(180);
          servo1.write(90);
          dataNumber++;
     if (dataNumber == IT2){
          servo1.write(IT2);
          servo1.write(180);
          servo1.write(90);
          dataNumber++;
     if (dataNumber == IT3){
          servo1.write(IT3);
          servo1.write(180);
          servo1.write(90);
          dataNumber++;
     if (dataNumber ==Order){
          servo1.write(IT1);
          servo1.write(180);
          servo1.write(90);
          servo1.write(IT2);
          servo1.write(180);
          servo1.write(90);
          servo1.write(IT3);
          servo1.write(180);
          servo1.write(90);
          dataNumber++;
void recvWithEndMarker() {
    static byte ndx = 0;
    char endMarker = '\n';
    char rc;
    if (Serial.available() > 0) {
        rc = Serial.read();
        if (rc != endMarker) {
            receivedChars[ndx] = rc;
            ndx++;
            if (ndx >= numChars) {
                ndx = numChars - 1;
        else {
            receivedChars[ndx] = '\0'; // terminate the string
            ndx = 0;
            newData = true;
void showNewNumber() {
    if (newData == true) {
        dataNumber = 0;             // new for this version
        dataNumber = atoi(receivedChars);   // new for this version
        Serial.print("This just in ... ");
        Serial.println(receivedChars);
        Serial.print("Data as Number ... ");    // new for this version
        Serial.println(dataNumber);     // new for this version
        newData = false;
Great tutorial on using Serial. Go here and scroll down to the section labeled Communication and read through the two on Serial.
http://forum.arduino.cc/index.php?topic=384198.0
I believe it is "cut straight to the chase" not cheese.
Anyhow, if I understand you, you want to be able to issue a command from a serial terminal in the form of ITx, and then have a command executed based on the value of x? There are a number of ways you can do that, but probably the way you're thinking, it can't be done - variable names disappear during compilation and are replaced by memory addresses.
You could receive the input into a 4 char array (3 + NULL) and then use strcmp to test against "IT1", etc, or you could assign each of your options a numeric value via the enum function, parse the incoming data stream a use a switch function.
Others will likely offer additional advice, but there's a start for you.
