I would try burning the bootloader before I gave up on the chip. No guarantees, but I have heard of several being fixed this way. It's also a good thing to learn if you are going to play/work with Arduino's.
Thank you for your response. I tried to install the bootloader using Arduino Mega as a programmer, but I got the following error:
"avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xf7
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xe0
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xe0
Error while burning bootloader."
Connected the capacitor. Connected Arduino Uno to the computer
You should not connect the target Uno to the computer. The Mega (Arduino as ISP) is the one connected to the computer and the ISP leads connect to the UNO.
Try it again.
With the Mega loaded with the Arduino as ISP sketch and not connected to the UNO I get this.
Arduino: 1.8.5 (Linux), Board: "Arduino/Genuino Uno"
/home/kprims/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14/bin/avrdude -C/home/kprims/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14/etc/avrdude.conf -v -patmega328p -cstk500v1 -P/dev/ttyACM0 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xDE:m -Ulfuse:w:0xFF:m
avrdude: Version 6.3-20171130
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/home/kprims/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino14/etc/avrdude.conf"
User configuration file is "/home/kprims/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/ttyACM0
Using Programmer : stk500v1
Overriding Baud Rate : 19200
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500
Description : Atmel STK500 Version 1.x firmware
Hardware Version: 2
Firmware Version: 1.18
Topcard : Unknown
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude: Device signature = 0x000000 (retrying)
avrdude: Yikes! Invalid device signature.
Double check connections and try again, or use -F to override
this check.
avrdude done. Thank you.
option enabled in File -> Preferences.
Thank you for your response. I did not connect the Arduino Uno to the computer to this time, but I got the following error message:
" ***failed;
avrdude: verification error, first mismatch at byte 0x0000
0x0f != 0x3f
avrdude: verification error; content mismatch
I did the following:
Wired the Mega (programmer to the Uno). Did not connect the capacitor to the Mega.
Connected the Mega to the computer, and I uploaded the ArduinoISP sketch.
I connected the capacitor.
Changed the Board to Arduino Uno, and changed the programmer to "Arduino as ISP."
Can it be that the issue is not with the boatloader? Can it be the chip?
Should I try replacing the chip of the Arduino Uno
I would try it. You mentioned the chip was getting hot in one of your other posts. If you do change the chip, monitor the chip closely for heat. You shouldn't have anything connected to your Uno when testing except for the leads used to program it.
It would help next time if you showed more of the error message.
Select File/Preferences and the Tic the Show verbose output during: upload
Then select "Copy error messages"
