Combined Code:
// SHT15 Temperature & Humidity Logger
// Libraries
#include <SdFat.h> // SD card file system library GNU GPL V3 (Version 20100818) http://code.google.com/p/sdfatlib/
#include <DS1302.h> // Real Time clock (RTC) lib (C) Henning Karlsen http://www.henningkarlsen.com/electronics/a_l_ds1302.php
#include <SHT1x.h> // SHT Temp and Humidity Library
#include <LiquidCrystal.h>
#include <AikoEvents.h>
using namespace Aiko;
// Connections
//IMPORTANT: for SD card code to work with datalogging shield a jumper is needed between digital 10 and 5
// Specify data and clock connections and instantiate SHT1x object - using pins 16 and 17 corresponds to the P2 4pin connector
#define dataPin 17
#define clockPin 16
SHT1x sht1x(dataPin, clockPin);
//create object to control an LCD.
LiquidCrystal lcd(9, 8, 7, 10, 14, 2); // this was 12,11,5,3,2
// Aiko Settings
int HumidityInterval = 5; // Delay between Humid Air (in seconds)
int DryInterval = 10; // Delay between Dry Air (in seconds) must be different from Humidity interval
int dryAirPin = 19; // Reed relay on digital pin 19
int humidAirPin = 18; // Reed relay on digital pin 18
int greenLEDpin=2; //LED file system / SD card syncing activity - not needed?
// RTC uses digital pin 3 (SCLK), pin 4 (I/O), pin 5 (CE)
// Init the DS1302 passing connection pin numbers
DS1302 rtc(6, 4, 3);
//define variables for SD card logging check these, sensiron SHT15 needs min 6.5 s between readings to avoid self-heating
int LOG_INTERVAL=7500; // mills between entries
int ECHO_TO_SERIAL=1; // echo data to serial port
int SYNC_INTERVAL=7500; // Sensor reading saved to SD card every x seconds
long syncTime = 0; // time of last sync()
// The objects to talk to the SD card
Sd2Card card;
SdVolume volume;
SdFile root;
SdFile file;
//Function Decleration
void sd_card(float,float); //sd card logging code use void sd_card(float,float,float) if using temp_f
//SETUP
// start serial port
Serial.println("Temperature & Humidity Sensor is Starting Up");
//Welcome Message
lcd.begin(16, 2);
lcd.clear();
lcd.setCursor(0, 0); // set the cursor to column 0, line 0
lcd.print("Sensor");
lcd.setCursor(0, 1); // set the cursor to column 0, line 1
lcd.print("initialising...");
delay(2000); // remove this delay?
// initialize the SD card
if (!card.init()) error("card.init");
// initialize a FAT volume
if (!volume.init(card)) error("volume.init");
// open root directory
if (!root.openRoot(volume)) error("openRoot");
// create a new file
char name[] = "LOGGER00.CSV";
for (uint8_t i = 0; i < 100; i++) {
name[6] = i/10 + '0';
name[7] = i%10 + '0';
if (file.open(root, name, O_CREAT | O_EXCL | O_WRITE)) break;
if (!file.isOpen()) error ("file.create");
file.writeError = 0;
// write header
file.println("Milliseconds since start, Date, Time, Temperature (*C), Humidity");
if (ECHO_TO_SERIAL) Serial.println("Milliseconds since start, Date, Time, Temperature (*C), Humidity");
pinMode(greenLEDpin, OUTPUT); //set SD card activity LED pin to output mode
digitalWrite(greenLEDpin,HIGH);
// attempt to write out the header to the file
if (file.writeError || !file.sync()) {
error("write header");
// Set the clock to run-mode, and disable the write protection
rtc.halt(false);
rtc.writeProtect(false);
// Set RTC date and time (if needed!)
//rtc.setDOW(FRIDAY); // Set Day-of-Week to FRIDAY
//rtc.setTime(12, 0, 0); // Set the time to 12:00:00 (24hr format)
//rtc.setDate(6, 8, 2010); // Set the date to August 6th, 2010
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
digitalWrite(greenLEDpin,LOW);
pinMode(dryAirPin, OUTPUT); // Set the dry air pin as an output
digitalWrite(dryAirPin, LOW);
pinMode(humidAirPin, OUTPUT); // Set the humid air pin as an output
digitalWrite(humidAirPin, LOW);
//pinMode(ledPin, OUTPUT); // Set the LED pin as an output
//digitalWrite(ledPin, LOW);
Events.addHandler(humidAir, HumidityInterval * 1000); // Every 'HumidityInterval' seconds
Events.addHandler(dryAir, DryInterval * 1000); // Every 'HumidityInterval' seconds
} //end setup
//Loop
void loop(void)
Events.loop();
// clear print error
// delay for the amount of time we want between readings
delay((LOG_INTERVAL -1) - (millis() % LOG_INTERVAL));
//get individual sensor temperatures
float temp_c;
// float temp_f;
float humidity;
// Read values from the sensor
temp_c = sht1x.readTemperatureC();
// temp_f = sht1x.readTemperatureF();
humidity = sht1x.readHumidity();
//log data to SD card
if ((millis()-syncTime) > SYNC_INTERVAL){
sd_card(temp_c,humidity);
syncTime=millis();
// (note: line 1 is the second row, since counting begins with 0):
// Print a message to the LCD.
lcd.clear();
lcd.print("Temperature");
lcd.print(temp_c); //send the data to the computer
lcd.print((char)223); // degree symbol
lcd.print("C");
delay (3750);
lcd.clear();
lcd.print("Humidity");
lcd.print(humidity);
lcd.print("%");
delay(3750);
} //end loop
void humidAir()
digitalWrite(dryAirPin, LOW); // Turn off dry air relay
digitalWrite(humidAirPin, HIGH); // Turn on humid air relay
void dryAir()
digitalWrite(dryAirPin, HIGH); // Turn on dry air relay
digitalWrite(humidAirPin, LOW); // Turn off humid air relay
//SD card error function
void error(char *str)
boolean flag=false;
Serial.print("error: "); Serial.println(str);
while(1){
digitalWrite(greenLEDpin, HIGH);
delay(100);
digitalWrite(greenLEDpin, LOW);
void sd_card(float temp_c,float humidity) //void sd_card(float temp_c,float temp_f,float humidity)
//log milliseconds since starting
long m = millis();
file.print(m); file.print(","); // milliseconds since start, I disabled this because it messes up the Columns when logged
//save current date and time
file.print(rtc.getDateStr()); file.print(",");
file.print(rtc.getTimeStr()); ;file.print(",");
file.print(temp_c);file.print(", ");
//file.print(temp_f);file.print(", ");
file.println(humidity);file.print(", ");
if (ECHO_TO_SERIAL){
Serial.print(m); Serial.print(", "); // milliseconds since start
Serial.print(rtc.getDateStr()); Serial.print(", ");
Serial.print(rtc.getTimeStr()); Serial.print(", ");
Serial.print(temp_c);Serial.print(", ");
//Serial.print(temp_f);Serial.print(", ");
Serial.println(humidity);
// blink LED to show we are syncing data to the card & updating FAT!
if (!file.sync()) error("sync");
if (file.writeError) error("write data");
return;
