Hello, I have a problem with my arduino nano. It does not work with batteries only works when connected by USB. connect pin 29 (GND) and 30 (VIN 5v). But still it does not work. please help.
(""hola, tengo un problema con mi arduino nano. no funciona con baterias solo funciona al estar conectado por USB. conecte el pin 29 (GND) y 30 (VIN 5v). Pero aun asi no funciona. ayuda porfavor."")
If your battery is able to deliver 5V (and not more), you might use the +5V pin.
But this bypasses any power protection of your Nano and is not recommended generally.
