Servo not receiving PWM signal - help needed
Hi readers
I have problem with my 9g (SG90) servo, when i properly connect all pins, servo doesn't respond.
I have tried with external power but unsuccessfully. After connecting and disconnecting 5v and ground makes servo move and i remember that servo worked some time ago but now it doesn't...
I'm using Arduino Nano and sweep library from IDE
I think it's problem with PWM connection from servo side
Connections:
Gnd - Brown
5v (internal or external) - Red
D5 (Pin 9) - Orange
Code:
#include <Servo.h>
Servo myservo; // create servo object to control a servo
// twelve servo objects can be created on most boards
int pos = 0; // variable to store the servo position
myservo.attach(9);
for (pos = 0; pos <= 180; pos += 1) { // goes from 0 degrees to 180 degrees
// in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(15); // waits 15ms for the servo to reach the position
for (pos = 180; pos >= 0; pos -= 1) { // goes from 180 degrees to 0 degrees
What did you use for external power?
When you used external power, did you connect the ground of that power supply to the ground of the arduino? This is needed.
