Arduino: 1.8.5 (Windows 7), Board: "Arduino/Genuino Uno"
Sketch uses 8762 bytes (27%) of program storage space. Maximum is 32256 bytes.
Global variables use 826 bytes (40%) of dynamic memory, leaving 1222 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino2\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino2\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\Alex\AppData\Local\Temp\arduino_build_317681/CNC_control.ino.hex:i
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x27
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino2\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xb7
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xb7
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xb7
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xb7
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xb7
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xb7
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xb7
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xb7
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xb7
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xb7
avrdude done. Thank you.
option enabled in File -> Preferences.
I was running my code last night, uploading with no problem. Left everything turned on as it was.
This morning I continued to write my sketch and have this problem.
I have most of the pins connected to something. Pins 0-5 are connected to TB6600 driver controllers with stepper motors connected. Pins 6 - 13 are connected to a 16 key keypad and A4,A5 are connected to I2C lcd display.
A temporary fix is to unplug the board from usb, unplug pins 0-5 then plug in the USB. Then it will load and I can continue to test the code. Is this normal? Should I get an i/o expansion board?
