hi everyone i got ads1115 works fine reading by it self but trying smooth out readings
in serial output you see V1 that's output of analog 0 on ads1115,
i have tried 3 different smoothing codes all get same output 1v
project dual voltage and current meter and with rtc and sd card datalogging , on mega
here's code im testing with
#include <Wire.h>
#include <Adafruit_ADS1015.h>
Adafruit_ADS1115 ads(0x48);
#define NUM_SAMPLES 64
int sum = 0; // sum of samples taken
unsigned char sample_count = 0; // current sample number
float Voltage = 0.0; // calculated voltage
float batteryVoltage = 0.0;
float V1 = 0.0;
void setup(void)
ads.begin();
void loop(void)
int16_t adc0; // we read from the ADC, we have a sixteen bit integer as a result
adc0 = ads.readADC_SingleEnded(0);
V1 = (adc0 * 0.1875)/1000;
// take a number of analog samples and add them up
while (sample_count < NUM_SAMPLES) {
sum += V1 ;
sample_count++;
delay(100);
Voltage = ((float)sum / (float)NUM_SAMPLES);
batteryVoltage = Voltage * 9.98;
Serial.print("AIN0: ");
Serial.print(adc0);
Serial.print("\tVoltage: ");
Serial.println(Voltage, 7);
Serial.print("\tV1: ");
Serial.println(V1, 7);
Serial.println(batteryVoltage, 7);
delay(200);
sum += V1 ;
sample_count++;
delay(100);
That code part does not what the comment implies. It sums 64 times the same measurement value with a complete delay of 6.4s. I think you simply forgot to read the other measurements...
V1 = (adc0 * 0.1875)/1000; // here you take a single A/D reading, and multiply it by 0.0001875
while (sample_count < NUM_SAMPLES) { // here you add that single reading 64x to the value "sum"
sum += V1 ;
sample_count++;
delay(100);
64 readings divided by 64 is the average of 64 readings.
One reading added 64x to a total, and divided by 64 is still one reading.
Leo..
tied moving code inside loop i think, still get same output 1v
sum += V1 ;
sample_count++;
delay(100);
ghost_reaper:
sum += V1 ;
sample_count++;
delay(100);
[/code]
Post the actual code you ran, that is both incomplete and has obvious syntax errors.
No, the read is not inside the loop, its before the loop. It must be inside the loop.
If you loop for a fixed number of times then use a for-loop, not a while-loop, its
more readable.
hi i do thanks for taking your time to help me, but im just abit lost right now sorry
didn't think be this hard to make output more stable
here's full code
#include <Wire.h>
unsigned long sum = 0; // sum of samples taken
float V1 = 0.0;
void setup(void)
ads.begin();
void loop(void)
sum += V1 ;
sample_count++;
delay(100);
Serial.print(adc0);
Serial.print("\tSum avg: ");
Serial.print("Battery Voltage");
What you posted is for sure not your actual code. This doesn't compile, there's a syntax error in it.
In this code (if you would fix it and actually start using it - pretending it's the real thing) you're still taking a single reading from our adc, then start to work on that single reading in the while loop. Take you readings inside the loop.
double sum = 0.0; // set the proper type & initialise the variable - that was another error in your code.
int adc0;
for (int i = 0; i < NUM_SAMPLES; i++) { // You ignored the advice to use a for loop!
adc0 = ads.readADC_SingleEnded(0); // take a sample
sum += (adc0 * 0.1875)/1000; // Add them all up - this are floating point numbers, won't work in the integer type in your code.
delay(100); // Doing this 64 times means this loop blocks the device for 6.4 seconds!
voltage = sum/NUM_SAMPLES; // Take the average. Note that it's customary to not start variable names with a capital. Style makes your code readable.
That should do.
It's really not hard to take an average of 64 readings, as long as you take 64 readings and not just one!
wvmarle:
sorry didn't notice it failed to upload and and found problem one line i add was missing ;
i tried your code and made all changes to code but avg increases each time
eg..
AIN0: 7461 Sum avg: 1.3988709
V1: 0.0000000
Battery Voltage13.9607315
AIN0: 7461 Sum avg: 2.7978088
V1: 0.0000000
Battery Voltage27.9221305
AIN0: 7461 Sum avg: 4.1967382
V1: 0.0000000
Battery Voltage41.8834457
AIN0: 7460 Sum avg: 5.5956554
V1: 0.0000000
Battery Voltage55.8446388
just before starts talking samples i add sum = 0.0;
now it works thanks very much & if i could i give you gold star
here's code for any one else
#include <Wire.h>
double sum = 0.0; // sum of samples taken
float voltage = 0.0; // calculated voltage
float V1 = 0.0;
int adc0;
void setup(void)
ads.begin();
void loop(void)
sum = 0.0;
delay(10); // delay * num_samples = 0.64
batteryVoltage = voltage * 9.935; //converts to dc volt's
Serial.print(adc0);
Serial.println(voltage, 4);
Serial.print("Battery Voltage: ");
Serial.println(batteryVoltage, 2);
