Kinect/Ardunio/Processing and 5 Motors
Here's some processing code I used at one point to get the kinect to talk to the arduino (I think it was mostly stolen from a book called Making Things See)
import processing.serial.*;
import SimpleOpenNI.*;
SimpleOpenNI kinect;
Serial arduinoport;
  size(1024, 480);
  textSize(20);
  if (Serial.list().length < 1) {
    println("No serial port seen. Quitting.");
    exit();
  if (Serial.list().length > 1) {
    print("There are multiple serial ports. Using the first one: ");
    println(Serial.list()[0]);
  arduinoport = new Serial(this, Serial.list()[0], 115200);
  //delay(2000); // Wait for arduino to reboot
  kinect = new SimpleOpenNI(this);
  kinect.enableDepth();
  kinect.enableUser(SimpleOpenNI.SKEL_PROFILE_ALL);
void draw() {
  kinect.update();
  PImage depth = kinect.depthImage();
  image(depth, 0, 0);
  IntVector userList = new IntVector();
  kinect.getUsers(userList);
  while (arduinoport.available() > 0) {
    char inByte = (char)arduinoport.read();
    print(inByte);
  boolean stopRobot = true; // Only move robot if someone is there
  for (int i=0; i < userList.size(); i++) {
    int userId = userList.get(i);
    if (kinect.isTrackingSkeleton(userId)) {
      float x = 0;
      float y = 0;
      float rotation = 0;
      // Get the position of the torso
      PVector torsopos = new PVector();
      float torsoconfidence = kinect.getJointPositionSkeleton(userId, SimpleOpenNI.SKEL_TORSO, torsopos);
      if (torsoconfidence > 0.5) {
        displayJoint(torsopos);
        float userPos = torsopos.x;
        userPos = map(userPos, -600, 600, 1000, -1000);
        userPos = constrain(userPos, -1000, 1000);
      PVector rightpos = new PVector();
      float rightconfidence = kinect.getJointPositionSkeleton(userId, SimpleOpenNI.SKEL_RIGHT_HAND, rightpos);
      PVector leftpos = new PVector();
      float leftconfidence = kinect.getJointPositionSkeleton(userId, SimpleOpenNI.SKEL_LEFT_HAND, leftpos);
      if (rightconfidence > 0.5 && leftconfidence > 0.5) {
        displayJoint(rightpos);
        displayJoint(leftpos);
        PVector differenceVector = PVector.sub(rightpos, leftpos);
        x = constrain(map(differenceVector.x, -600, 600, -1000, 1000), -1000, 1000);
        y = constrain(map(differenceVector.z, -200, 200, -1000, 1000), -1000, 1000);
        if (differenceVector.y > 0) { // If left hand is higher
          x = -x;
          y = -y;
        //print(x); print("\t"); print (y); print("\t");
      //println(userPos);
      String arduinocmd = String.format("<r,%.0f,%.0f,%.0f>", x, y, rotation);//"<r,"+x+","+y+"," + rotation + ">";
      fill(50);
      rect(725, 175, 250, 250);
      fill(255);
      ellipse(map(x, -1000, 1000, -100, 100) + 850, map(y, -1000, 1000, -100, 100) + 300, 20, 20);
      //println (arduinocmd);
      arduinoport.write(arduinocmd);
      stopRobot = false;
  if (stopRobot) {
    arduinoport.write("<r,0,0,0>");
void onNewUser(int userId) {
  background(0);
  fill(255);
  text("Start pose detection", 700, 30);
  kinect.startPoseDetection("Psi", userId);
void onEndCalibration(int userId, boolean successful) {
  background(0);
  fill(255);
  if (successful) {
    text("    User Calibrated!", 700, 30);
    kinect.startTrackingSkeleton(userId);
  else {
    text("    Failed to calibrate user", 700, 30);
void onStartPose(String pose, int userId) {
  background(0);
  fill(255);
  text("Started pose for user " + userId, 700, 30);
  kinect.stopPoseDetection(userId);
  kinect.requestCalibrationSkeleton(userId, true);
void displayJoint(PVector joint) {
  PVector converted = new PVector();
  kinect.convertRealWorldToProjective(joint, converted);
  pushMatrix();
    noStroke();
    fill(255,0,0);
    ellipse(converted.x, converted.y, 20, 20);
  popMatrix();
And here's corresponding arduino code to control a robot with a library I wrote myself (just replace bot.RunMotors with whatever you want to move): arduino/circlebot/move_with_serial at master · AdamCDunlap/arduino · GitHub
