Parallax Gyroscope Module 3-Axis L3G4200D sample code
Can someone explain the elements of the code to me that I don't understand
Highlighted in bold in the code with my comments
[b]#define  CTRL_REG1  0x20    //whats this doing, i can see its used in gyrosensitivity() but I cant follow the logic of it all
#define  CTRL_REG2  0x21
#define  CTRL_REG3  0x22
#define  CTRL_REG4  0x23
#define  CTRL_REG5  0x24
#define  CTRL_REG6  0x25
[/b]
int gyroI2CAddr=105;
int gyroRaw[3];                         // raw sensor data, each axis, pretty useless really but here it is. //gyroRaw is an array with 3 columns, has nothing in them
double gyroDPS[3];                      // gyro degrees per second, each axis  //double = double precision floating point number //also an array of 3 columns with nothing in them
[b]float heading[3]={0.0f};         //whats the F doing in this? Why can you do this with curly brackets??       // heading[x], heading[y], heading [z][/b]
int gyroZeroRate[3];                    // Calibration data.  Needed because the sensor does center at zero, but rather always reports a small amount of rotation on each axis.
int gyroThreshold[3];                   // Raw rate change data less than the statistically derived threshold is discarded.
#define  NUM_GYRO_SAMPLES  50           // As recommended in STMicro doc
#define  GYRO_SIGMA_MULTIPLE  3         // As recommended
[b]
float dpsPerDigit=.00875f;       //once again, whats up with the f       // for conversion to degrees per second[/b]
  Wire.begin();
  setupGyro();
  calibrateGyro();
  updateGyroValues();
  updateHeadings();
  //testCalibration();
  printDPS();
  Serial.print("   -->   ");
  printHeadings();
  Serial.println();
void printDPS()
  Serial.print("DPS X: ");
  Serial.print(gyroDPS[0]);
  Serial.print("  Y: ");
  Serial.print(gyroDPS[1]);
  Serial.print("  Z: ");
  Serial.print(gyroDPS[2]);
void printHeadings()
  Serial.print("Heading X: ");
  Serial.print(heading[0]);
  Serial.print(heading[1]);
  Serial.print(heading[2]);
void updateHeadings()
  float deltaT=getDeltaTMicros();
  for (int j=0;j<3;j++)
    heading[j] -= (gyroDPS[j]*deltaT)/1000000.0f;
// this simply returns the elapsed time since the last call.
unsigned long getDeltaTMicros()
[b]{
  static unsigned long lastTime=0;
  unsigned long currentTime=micros();
  unsigned long deltaT=currentTime-lastTime;       //isnt lastTime always 0 because of the first line in this function??
  if (deltaT < 0.0)
     deltaT=currentTime+(4294967295-lastTime);  //where has this big number come from
  lastTime=currentTime;
  return deltaT;[/b]
// I called this from the loop function to see what the right values were for the calibration constants.
// If you are trying to reduce the amount of time needed for calibration just try not to go so low that consecutive
// calibration calls give you completely unrelated data.  Some sensors are probably better than others.
void testCalibration()
  calibrateGyro();
    Serial.print(gyroZeroRate[j]);
    Serial.print("  ");
    Serial.print(gyroThreshold[j]);
    Serial.print("  ");
  Serial.println();
  return;
// The settings here will suffice unless you want to use the interrupt feature.
void setupGyro()
[b]  gyroWriteI2C(CTRL_REG1, 0x1F);        // Turn on all axes, disable power down
  gyroWriteI2C(CTRL_REG3, 0x08);        // Enable control ready signal
  setGyroSensitivity500();
//I guess I need to look inside the libraries to understand what this is doing and why
[/b]
  delay(100);
// Call this at start up.  It's critical that your device is completely stationary during calibration.
// The sensor needs recalibration after lots of movement, lots of idle time, temperature changes, etc, so try to work that in to your design.
void calibrateGyro()
[b]  long int gyroSums[3]={0};
  long int gyroSigma[3]={0};     //i dont understand what this is saying as I dont what the curly brackets are doing[/b]
[b]  for (int i=0;i<NUM_GYRO_SAMPLES;i++)
    updateGyroValues();
      gyroSums[j]+=gyroRaw[j];
      gyroSigma[j]+=gyroRaw[j]*gyroRaw[j];
// no explanation about whats trying to be achieved here, apart from its used for the calibration
// whats gyro sums? whats gyro sigma
// not sure why the maths works
[/b]
    int averageRate=gyroSums[j]/NUM_GYRO_SAMPLES;
    // Per STM docs, we store the average of the samples for each axis and subtract them when we use the data.
    gyroZeroRate[j]=averageRate;
    // Per STM docs, we create a threshold for each axis based on the standard deviation of the samples times 3.
    gyroThreshold[j]=sqrt((double(gyroSigma[j]) / NUM_GYRO_SAMPLES) - (averageRate * averageRate)) * GYRO_SIGMA_MULTIPLE;
void updateGyroValues() {
  while (!(gyroReadI2C(0x27) & B00001000)){}      // Without this line you will get bad data occasionally
  //if (gyroReadI2C(0x27) & B01000000)
  //  Serial.println("Data missed!  Consider using an interrupt");
  int reg=0x28;
    gyroRaw[j]=(gyroReadI2C(reg) | (gyroReadI2C(reg+1)<<8));
    reg+=2;
  int deltaGyro[3];
    deltaGyro[j]=gyroRaw[j]-gyroZeroRate[j];      // Use the calibration data to modify the sensor value.
    if (abs(deltaGyro[j]) < gyroThreshold[j])
      deltaGyro[j]=0;
    gyroDPS[j]= dpsPerDigit * deltaGyro[j];      // Multiply the sensor value by the sensitivity factor to get degrees per second.
void setGyroSensitivity250(void)
  gyroWriteI2C(CTRL_REG4, 0x80);        // Set scale (250 deg/sec)
void setGyroSensitivity500(void)
  dpsPerDigit=.0175f;
  gyroWriteI2C(CTRL_REG4, 0x90);        // Set scale (500 deg/sec)
void setGyroSensitivity2000(void)
  dpsPerDigit=.07f;
  gyroWriteI2C(CTRL_REG4,0xA0);
int gyroReadI2C (byte regAddr) {
  Wire.beginTransmission(gyroI2CAddr);
  Wire.write(regAddr);
  Wire.endTransmission();
  Wire.requestFrom(gyroI2CAddr, 1);
  while(!Wire.available()) {};
  return (Wire.read());
int gyroWriteI2C( byte regAddr, byte val){
  Wire.write(val);
