I will be elaborating more on the how's and why's... But for now here is a simple proof of concept with Arduino .
Next time will be integrated with Serial.read , but for now, this will do !
Compatible with all the printable characters of the ascii table ( starting from SPACE [ascii 32] to ~[ascii 126])
A more user friendly version of the code.
As this subject includes maths as well, id guess this would be perfect for a subject in younger users workshops !
// "CAESAR CIPHER"
// A simple "CAESAR CIPHER"ing project - http://dubworks.blogspot.co.uk/
// Number_of_Characters = 96
// [ from "ascii'" character number 32-decimal; 040-OCT; 20-HEX; 00100000-BIN ==> "SPACE"
// to "ascii'" character number 126 decimal; 176-OCT; 7E-HEX; 01111110-BIN; ==> "~" Equivalency sign - tilde
// Caesar cipher ==> C=(P+s) Mod (Number_of_Characters)
// P = numerical equivalent of character plaintext
// C = Numerical equivalent of ciphertext character
// s = number of shifts/adds
// Ke== Enciphering Key
// Kd== Deciphering key
// Ke= s = 3 ==> (P+s) mod (Number_of_Characters)
// Kd = -s = -3 ==> (C -s)mod (Number_of_Characters)
// For more on Caesar cipher - http://en.wikipedia.org/wiki/Caesar_cipher
#define Nchars 96 // starting at 32 up to 126 in the ascii table
#define n_shift 3 // shift desired
char plaintext[]=
"Arduino to cipher this#"};
// 'A','r','d','u','i','n','o',' ', 't','o',' ','c','i','p','h','e','r',' ','t','h','i','s', '#'};
char ciphered[sizeof(plaintext)];
boolean stringComplete = true; // whether the string is complete
// Insert your setup code here, to run once:
uint8_t i;
// Serial.println(sizeof(plaintext));
// Insert your main code here, to run repeatedly:
while(Serial)
if(stringComplete==true){
Serial.println ("Arduino Caesar Cipher v1");
Serial.println ("");
cphr();
Serial.println(" ");
void cphr()
uint8_t sizeofarray = sizeof(plaintext);
uint8_t i;
for(i=0;i<sizeofarray;i++)
uint16_t retrieved;
retrieved=plaintext[i];
if(retrieved == 0){
ciphered[i]=0;
Serial.print("i- ");
Serial.println(i);
Serial.println("null CHARACTER ");
// The use of goto's is highly frowned upon...
// ...but can be quite handy as well !
goto bailout;
Serial.print("P original- - ");
Serial.println(retrieved);
//retrieved -=32; // Subract Ascii_offset
Serial.print("P - Offset = ");
Serial.println(retrieved-32);
uint16_t c =((retrieved-32) + n_shift)% Nchars; // check blog post for more info on this
Serial.print("C original - ");
Serial.println(c);
c +=32; // add the Ascii_offset
Serial.print("C + Offset = ");
Serial.println(c);
ciphered[i]=c;
Serial.println(i);
Serial.println(c);
Serial.print("C_array- ");
Serial.println(ciphered[i]);
Serial.print("Alphaarray- ");
Serial.println(plaintext[i]);
delay(50);
bailout:// :)
displayResults();
stringComplete = false;
void displayResults(){
uint8_t i;
Serial.print("plaintext to encipher- ");
Serial.print(plaintext[i]);
delay(10);
Serial.print("Ciphered_array- ");
Serial.print(ciphered[i]);
delay(50);
