Serial Plotter isn't working anymore
Hi everyone,
I made a code to use a mpu6050 accelerometer :
#include <MPU6050_tockn.h>
#include <Wire.h>
MPU6050 mpu6050(Wire);
  Wire.begin();
  mpu6050.begin();
  mpu6050.calcGyroOffsets(true);
  mpu6050.update();
  Serial.print(mpu6050.getAccY()*9.81);
  Serial.print(",");
  if ((millis() / 1000) % 2 == 0) {
    Serial.print(1);
  else {
    Serial.print(0);
  Serial.print(",");
At first everything was working fine, I could visualize data from both the serial monitor and plotter but in the last couple of days the plotter stopped showing the data after a few seconds even though I didn't change anything in the code and I can still see my data coming from the sensor on the monitor. Does anyone know how I could fix this?
Here are the details of what I have:
Board: Arduino Nano
Processor: ATmega328P (Old Bootloader)
Programmer: Arduino as ISP
Thanks!
Note: I did try to change (in the IDE) the processor and the programmer but it didn't change the results
PrSx:
Are you sure about that? That code never would have worked. Each data set must be followed by a newline. But your code never prints a newline to Serial. So the data is plotted as a single set with an infinite number of elements. To make it work, you need to change the second to last line from:
  Serial.print(",");
to:
  Serial.println(",");
OK so I changed Serial.print(mpu6050.getAccY()) to : Serial.println(mpu6050.getAccY()) and it works fine now.
It also works with what you suggested (even a bit better).
Huge thanks to you!
You're welcome. I'm glad to hear it's working now.
Enjoy!
Per
