I'm triying to read values from an anemometer. I was using this code in UNO board, but I move my project to MKR. the problem is qhen I compiled the code but give me some errors in interrupts.
#include <math.h>
#define WindSensorPin (5) // The pin location of the anemometer sensor
volatile unsigned long Rotations; // cup rotation counter used in interrupt routine
volatile unsigned long ContactBounceTime; // Timer to avoid contact bounce in interrupt routine
float WindSpeed; // speed miles per hour
pinMode(WindSensorPin, INPUT);
attachInterrupt(digitalPinToInterrupt(WindSensorPin), isr_rotation, FALLING);
Serial.println("Davis Wind Speed Test");
Serial.println("Rotations\tMPH");
Rotations = 0; // Set Rotations count to 0 ready for calculations
sei(); // Enables interrupts
delay (3000); // Wait 3 seconds to average
cli(); // Disable interrupts
/* convert to mp/h using the formula V=P(2.25/T)
V = P(2.25/3) = P * 0.75 */
WindSpeed = Rotations * 0.75;
Serial.print(Rotations); Serial.print("\t\t");Serial.println(WindSpeed);
// This is the function that the interrupt calls to increment the rotation count
void isr_rotation () {
if ((millis() - ContactBounceTime) > 15 ) { // debounce the switch contact.
Rotations++;
ContactBounceTime = millis();
Does anybody played with anemometer and MKR boards? any idea what I'm doing wrong?
thank's
Eduard
