The Display uses ILI9341 and not a SSD1289. As far as I know, there is no official UTFT driver for this. But I am sure that there will be several users that have hacked UTFT to drive this display.
Your adapter is designed for a Mega2560. You should buy the proper Due adapter from ColdTears.
(translated)
Tested with UTFT libraries, Electronics - Henning Karlsen link, set in the demo UTFT_320x240 UTFT myGLCD (SSD1289,38,39,40,41); no flicker, ATTENTION is powered by 3.3 volts, better to use a shield, as TFT LCD Mega Shield v2.2
or
I purchased this screen for use with an Arduino Mega. Using the UTFT library, I have been able to access all the features of this screen - LCD, Touch and SD card access. It is excellent value, has good colour rendition and works reliably. UTFT Setup is: UTFT myGLCD(SSD1289,38,39,40,41); UTouch myTouch(6,5,4,3,2); const int chipSelect = 53; pinMode(53, OUTPUT); Connections are: LCD Pin - Function - Arduino Pin 1 - Gnd -Ground 2 - VCC - 5V 3 - NC - No Connection 4 - RS - D38 5 - WR - D39 6 - RD - 3.3V
or
Nothing to complain,just connect to Arduino UNO in 16 bit mode,as is indicated in the UTFT REQUIREMENTS PDF and load the sketch from UTFT examples,modify the name of the TFT in SSD1289 and will work for sure.
So don't know, unless the comments are from some other product or the seller is selling a different product now then I'd more bet it on the SSD1289 controller (it's even in the URL www.banggood.com/3_2-Inch-SSD1289-TFT...).
david_prentice:
i almost tried every possible combinations that related with utft
I do not have either SSD1289 or the ILI9341 version. But as far as I understand from recent posts, BangGood is shipping ILI9341 now.
The original SSD1289 display is marked TFT-320QVT
The new ILI9341 display is marked TFT-320QVT9341
Yes, the URL says SSD1289. When have Chinese suppliers worried about accuracy in their descriptions?
The OP has just got to read the model number that is printed on the display to see which controller.
At least it is easy for the punter to read the printed legend. The red 2.4" and blue 2.8" displays are shipped with different controllers every week. You can only identify the controller in software. If there is a printed legend, it is not always truthful.
The Mega adapter will plug into a Due board. However, all the data bus pins are mapped to random Port bits.
By the time that you have mapped the Mega pins to the respective Due Port bits, the Due will be no faster than using a Mega in the first place. You have to bit-bash the SD in software.
If you use a Due adapter, the data bus is mapped efficiently. The SD card connects to the Due hardware SPI.
david_prentice:
David.
Thank you so much for your answer
I can't use it then...
Yes, you can use it with the Due. I am just saying that the Mega adapter maps the data bus nicely to PORTA, PORTC of a MEGA2560. The display will work very well on the MEGA2560.
Please read the printed legend on your pcb. Does it say TFT-320QVT9341 or TFT-320QVT ?
david_prentice:
The white backlight is because you are using 5v connections. You must use 3v connections.
Connections are :
5v/3v power,
gnd,
5v with 33ohm resistor for LED. Do not connect LED directly to 5v as it will burn out.
The rest of the connections are connected through a CD4050 which reduces to 3v. If you don't want to use a CD4050 you can also use resistors divider, first 2k2 then 4k7.
Mustafa merhaba,
Çalıştırmayı başardın mı. bendede aynı sıkıntı var.
for those who English speakers. I have similar problem that I only see white screen.
if anybody could success to make it work can you please provide connection scheme. every information you will provide will appreciated.
You simply buy a 40-pin TFT Adapter Shield for the Mega.
Your display plugs into the Adapter. The Adapter plugs into the Mega2560. The Adapter contains 5V to 3.3V level shifters.
UTFT v2.8.2 supports the ILI9341 in 16-bit parallel mode.
If you use a Due, the logic levels are 3.3V. You can wire directly to the display.
If you use a 5V Mega2560, you must provide level shifters for about 26 channels.
But still my TFT 320QVT_9431 LCD is not working. Just display white screen. So I thought it is because the shield is not compatible with that LCD. That's why I thought to wire LCD with Arduino Mega. Please give me a solution
