I have a sketch where I have a light sensor printing the values from the analog pin whenever the light values are less that 400. Works fine but I would like to know how I would include a number next to the value for the number of times it detected light in this range. Right now, the values just scroll thru the screen as I'm capturing a series of flashes from my camera and I would like to count how many times the flash triggered the light sensor. Could someone post some example code that would accomplish this? I dont need anything fancy, just a way for a number to increment each time the value is less than 400 and print it out.
Yeah, except I have no idea how I would go about doing that. I'm a programming idiot. I've been basically copying and pasting examples from the playground to get anything done.
**Edited, again. It's more complicated
AnalogReadSerial
Reads an analog input on pin 0, prints the result to the serial monitor
This example code is in the public domain.
int Number = 0;
boolean prev = false;
int sensorValue = analogRead(A0);
if ( sensorValue < 400 && !prev )
Number++;
Serial.print("\n Sensor readings just fall below 400: ");
Serial.print( sensorValue );
Serial.print("\t It happened ");
Serial.print( Number );
Serial.print("\t times");
delay(100);
prev = true;
if ( sensorValue >= 400 )
prev = false;
Not tested
Missed a trailing }, I think.
Yes, I corrected it. Thanks.
