Flavi71:
Scusa il ritardo.
Lascia stare lo schema dei collegamenti del post #34. Quelli giusti sono:
buttonPin = D2 (pulsante del contatore)
buttonReset = D4 (pulsante di reset)
CLK = D9
LOAD-CS = D10
DIN = D12Con questo codice DEVE funzionare:
//State change detection (edge detection)
//We always have to include the library
#include "LedControl.h"
Now we need a LedControl to work with.
pin 12 is connected to the DataIn
pin 9 is connected to the CLK
pin 10 is connected to LOAD
We have only a single MAX72XX.
LedControl lc=LedControl(12,9,10,1);
/* The circuit:
- buttonpin attached to pin 2 from +5V
- buttonreset attached to pin 4 from +5V
- 10 kilohm resistor attached to pin 2&4 from ground
// this constant won't change:
#define buttonPin 2 // the pin that the pushbutton is attached to
#define buttonReset 4 // the pin that the buttonreset is attached to
// Variables will change:
int contatore = 0; // counter for the number of button presses
int buttonState = 0; // current state of the button
int lastButtonState = 0; // previous state of the button
int unita = 0;
int decine = 0;
int centinaia = 0;
int tmp=0;
void setup(){
The MAX72XX is in power-saving mode on startup,
we have to do a wakeup call
lc.shutdown(0,false);
/ Set the brightness to a medium values /
lc.setIntensity(0,8);
/ and clear the display */
lc.clearDisplay(0);
// initialize the button pin as a input:
pinMode(buttonPin, INPUT);
pinMode(buttonReset, INPUT);
// read the pushbutton input pin:
// compare the buttonState to its previous state
if (buttonState != lastButtonState) {
// if the state has changed, increment the counter
if (buttonState == HIGH) {
// if the current state is HIGH then the button went from off to on:
contatore++;
tmp=contatore;
unita=tmp%10;
tmp=tmp/10;
decine=tmp%10;
centinaia=tmp/10;
lc.setDigit(0,2,(byte)centinaia,false);
lc.setDigit(0,1,(byte)decine,false);
lc.setDigit(0,0,(byte)unita,false);
// Delay a little bit to avoid bouncing
delay(50);
// save the current state as the last state, for next time through the loop
lastButtonState = buttonState;
// if the buttonreset is pressed reset the buttonpushcounter
if (digitalRead(buttonReset) == HIGH){
(contatore = 0);
lc.clearDisplay(0);
Fammi sapere. Flaviano
Ciao Flavi71 scusami per il ritardo, allora ho aggiunto una resistenza al pin ISET del max7219 ogni volta che premo il pulsante comincia a contare solo che lo stato iniziale del display è spento come premo si accende.. come faccio a farlo stare acceso al primo stato? ho notato anche che conta dall'ultima cifra.. mi spiego meglio: invece di contare 001, 002.. mi conta 100,200 e cosi via come risolvo?
GRAZIE per il tempo che mi stai dando
Fammi sapere
FuryMan
