Hello!
writing
root@Arduino:~# opkg update
I have this fault:
Downloading http://download.linino.org/dogstick/all-in-one/latest/packages//Packages.gz.
wget: bad address 'download.linino.org'
Downloading http://download.linino.org/dogstick/all-in-one/latest/packages//Packages.sig.
Signature check failed.
Remove wrong Signature file.
Collected errors:
* opkg_download: Failed to download http://download.linino.org/dogstick/all-in-one/latest/packages//Packages.gz, wget returned 1.
* opkg_download: Failed to download http://download.linino.org/dogstick/all-in-one/latest/packages//Packages.sig, wget returned 1.
root@Arduino:~#
any suggestions please
Can you
ping download.linino.org
PING download.linino.org (88.198.63.58): 56 data bytes
64 bytes from 88.198.63.58: seq=0 ttl=39 time=129.515 ms
64 bytes from 88.198.63.58: seq=1 ttl=39 time=127.971 ms
64 bytes from 88.198.63.58: seq=2 ttl=39 time=128.162 ms
Thanks for the suggestion!
root@Arduino:~# ping download.linino.org
ping: bad address 'download.linino.org'
root@Arduino:~#
it is possible my yun is only on the lan and it can not get out on the net?
That's certainly what it looks like.
What do you get from
ifconfig
eth1 Link encap:Ethernet HWaddr 90:A2:DA:F9:04:27
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
Interrupt:4
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:59 errors:0 dropped:0 overruns:0 frame:0
TX packets:59 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:4895 (4.7 KiB) TX bytes:4895 (4.7 KiB)
wlan0 Link encap:Ethernet HWaddr 90:A2:DA:F1:04:27
inet addr:192.168.2.206 Bcast:192.168.2.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:1056773 errors:0 dropped:160413 overruns:0 frame:0
TX packets:15782 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:32
RX bytes:177319357 (169.1 MiB) TX bytes:3532792 (3.3 MiB)
Are you working in a serial terminal or ssh session?
Thanks for your help!
I use ssh via Putty
root@Arduino:~# ifconfig
eth1 Link encap:Ethernet HWaddr 90:A2:DA:F8:0C:82
inet addr:192.168.0.122 Bcast:192.168.0.255 Mask:255.255.255.0
RX packets:1423 errors:0 dropped:76 overruns:0 frame:0
TX packets:543 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:187086 (182.7 KiB) TX bytes:85548 (83.5 KiB)
Interrupt:4
RX packets:41 errors:0 dropped:0 overruns:0 frame:0
TX packets:41 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:3257 (3.1 KiB) TX bytes:3257 (3.1 KiB)
wlan0 Link encap:Ethernet HWaddr 90:A2:DA:F0:0C:82
RX packets:56 errors:0 dropped:6 overruns:0 frame:0
TX packets:34 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:7650 (7.4 KiB) TX bytes:5558 (5.4 KiB)
It looks like you are connected through the Ethernet port and WiFi on the same IP address. Try unplugging the Ethernet or turning off the WiFi.
When I plug in the Ethernet with the WiFi connected I can still ping linino.org but the interfaces have different addresses:
64 bytes from 88.198.63.58: seq=0 ttl=39 time=129.029 ms
64 bytes from 88.198.63.58: seq=1 ttl=39 time=131.320 ms
64 bytes from 88.198.63.58: seq=2 ttl=39 time=128.088 ms
64 bytes from 88.198.63.58: seq=3 ttl=39 time=128.072 ms
64 bytes from 88.198.63.58: seq=4 ttl=39 time=127.965 ms
^C
--- download.linino.org ping statistics ---
5 packets transmitted, 5 packets received, 0% packet loss
round-trip min/avg/max = 127.965/128.894/131.320 ms
:~# ifconfig
inet addr:192.168.2.211 Bcast:192.168.2.255 Mask:255.255.255.0
RX packets:704 errors:0 dropped:13 overruns:0 frame:0
TX packets:49 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:129904 (126.8 KiB) TX bytes:7135 (6.9 KiB)
Interrupt:4
RX packets:22 errors:0 dropped:0 overruns:0 frame:0
TX packets:22 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:2098 (2.0 KiB) TX bytes:2098 (2.0 KiB)
RX packets:85582 errors:0 dropped:18553 overruns:0 frame:0
TX packets:1512 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:14109920 (13.4 MiB) TX bytes:200752 (196.0 KiB)
Have you configured the Yun to have a static address or are you using DHCP?
as noted now is disabled the wireless connection
I have a static address:192.168.0.122
inet addr:192.168.0.122 Bcast:192.168.0.1 Mask:255.255.255.0
RX packets:458 errors:0 dropped:12 overruns:0 frame:0
TX packets:494 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:48213 (47.0 KiB) TX bytes:174119 (170.0 KiB)
Interrupt:4
RX packets:1584 errors:0 dropped:0 overruns:0 frame:0
TX packets:1584 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:107568 (105.0 KiB) TX bytes:107568 (105.0 KiB)
but I still have
thank you very much
I believe your problem is in your network configuration. I am no networking guru, that's why I use DHCP, it all happens automagically. If you can I would recommend using DHCP.
If you have to use a static address, here is the output from my route command it may help you:
:~# route
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
default 192.168.2.1 0.0.0.0 UG 0 0 0 wlan0
default 192.168.2.1 0.0.0.0 UG 10 0 0 eth1
192.168.2.0 * 255.255.255.0 U 0 0 0 wlan0
192.168.2.0 * 255.255.255.0 U 10 0 0 eth1
Thank you so much for your help and patience!
I switch as recommended to DHCP, and finally I have:
64 bytes from 88.198.63.58: seq=0 ttl=47 time=52.930 ms
64 bytes from 88.198.63.58: seq=1 ttl=47 time=52.410 ms
266 packets transmitted, 265 packets received, 0% packet loss
round-trip min/avg/max = 51.220/52.615/87.654 ms
which indicates that finally works!!!!
system
April 30, 2014, 6:22pm
10
I had this problem as well although I had DCHP enabled on my wifi connection.
I found it seemed to fix itself if I reconnected to the wifi. In the LUCI configuration panel, go to the network tab and click "reconnect" on the network you are connecting through. This should refresh the settings on the Yun.
I had the same problem with bad address and final deleted the link /etc/resolv.conf to /tmp/resolv.conf that just had
search lan
nameserver 127.0.0.1
I then used echo to create a new /etc/resolv.conf that had the following so am using google DNS servers
nameserver 8.8.8.8
nameserver 8.8.4.4
I can now run opkg update with no problem
Probably not the correct way to do it, but it works
rgb
70agiuseppe:
Well, did you set only the static IP address and subnet mask (as that is the only part that can be taken from the ifconfig output)?
[/quote]
[quote][code] ping download.linino.org
ping: bad address 'download.linino.org '
That can have two possible reasons:
you set only the IP address but not the gateway address
you did not set (properly) the DNS server addresses
Ralf[/code]
system
June 15, 2014, 8:01am
13
mine did that yesterday .... 14/06/2014.
site was down!
system
September 10, 2014, 8:28am
16
Hi, I read in this forum, but I do not understand how to put static IP with DHCP switch?.
Thanks a lot.
Why do you want to do that? Is your problem related to the topic (opkg and installing additional softwares) ?
system
October 22, 2014, 3:19pm
18
rbradley:
search lan
nameserver 8.8.8.8
nameserver 8.8.4.4
rgb
Thanks! Correct or not, this worked for me, too (using a static IP).
system
November 15, 2014, 3:17pm
19
I can ping download.linino.org and still get the error message.
Obviously there must be another reason than a connectivity problem.
What does "Remove wrong Signature file." mean? Is this a recommendation? Where is the signature file to be removed?
Any ideas?
Thank you
root@Webserver:~# ping download.linino.org
64 bytes from 88.198.63.58: seq=0 ttl=42 time=126.389 ms
^C
round-trip min/avg/max = 125.782/127.003/127.756 ms
root@Webserver:~# opkg update
Downloading http://downloads.arduino.cc/openwrtyun/1/packages/Packages.gz .
Updated list of available packages in /var/opkg-lists/attitude_adjustment.
Downloading http://downloads.arduino.cc/openwrtyun/1/packages/Packages.sig .
root@Webserver:~#
system
November 15, 2014, 3:54pm
20
PS: I just installed the latest image (NOV14) and now it works again.
The only difference "before" and "after" is the new image file.
It probably overwrote the file with the wrong information.
I don't suggest this is a great solution, leveling the machine and starting from scratch, but it is another strong indicator that static IPs are not the underlying issue, but a corrupt file on the Yun.
I'll now assign again static IPs and check if it still works. I can't see why this should have anything to do with static IPs (as long as it's done right).
