Hey guys,
I want to sense the value of a potmeter and connect my ESP32 to wifi. However, when I connect the ESP32 to WiFi, the potmeter value returns only 4094. If I do not connect it to WiFi, it does work and does return the real-time value.
This is the code that does work:
#include <WiFi.h>
#include <PubSubClient.h>
/* change it with your ssid-password */
const char* ssid = "AndroidAP";
const char* password = "pkjl2388";
/* this is the IP of PC/raspberry where you installed MQTT Server */
const char* mqtt_server = "192.168.43.1";
/* create an instance of PubSubClient client */
WiFiClient lightPotmeter;
PubSubClient client(lightPotmeter);
/* topics */
#define LIGHT_TOPIC "smarthome/room1/light"
long lastMsg = 0;
char msg[20];
int potPin = 4; // select the input pin for the potentiometer
int val = 0; // variable to store the value coming from the sensor
val = analogRead(potPin);
Serial.println("val=");
Serial.println(val);
delay(100);
Here is the code that does not work:
#include <WiFi.h>
/* topics */
long lastMsg = 0;
char msg[20];
// We start by connecting to a WiFi network
Serial.println();
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
/* configure the MQTT server with IPaddress and port */
client.setServer(mqtt_server, 1883);
delay(100);
What can I do to make the ESP connect with WiFi while returning me the real-time value of the potmeter?
I am curious to your thoughts, many thanks in advance!
