You got it RW!!!!!
The delay was the problem, so instead of putting the 2nd message after the delay I've put it in my else loop and it's working now!!!!
// If motion is detected, turn the onboard LED on:
if (motionStatus == HIGH){
motionStatus = 1;
//Serial.print(motionStatus);
digitalWrite(LED_PIN, HIGH);
digitalWrite(RELAY_PIN_1, HIGH);
//Sending value to OpenHab with MQTT
Serial.print("The value of motionStatus is: ");
Serial.println(motionStatus);
Serial.print("Sending PIR state ");
Serial.println(presence[motionStatus]);
String pubString = String(presence[motionStatus]);
pubString.toCharArray(message_buff, pubString.length()+1);
client.publish("Boubounouche/Halloween/PIR", message_buff);
delay (10000); // Smoke Machine ON
trigger = !trigger; // trigger is true
digitalWrite(LED_PIN, LOW);
digitalWrite(RELAY_PIN_1, LOW);
delay(10000);
else // Otherwise send MQTT nobody message and turn off relay
if (trigger == true){
motionStatus =0;
trigger = !trigger; // trigger is false
